Morimoto 7" headlight adapter first look and install + Super7 Bi-LED
2k2wranglerx
2k2wranglerx
Ryan
Pittsburgh, PA
2018 rubicon JL
  • Thread starter
  • Thread Starter
  • #16
obiwankabaldi
Lew
Rochester NY
Jeep Wrangler JL
I do not know what is going on. Got them installed but neither of them work. I do have a Sport S and wondering if there is a interface with the plugs that is not correct. I tried them both and swapped some components around wondering if there was a problem with one of them. NADA, NOTHING! Neither of them lit up. I did accomplish to change out the satin grill but really bummed about the super 7's not working....
KCwrangler
Kansas City Suburbs
2018 Wrangler Unlimited Sahara JL
Did you file off that extra little plastic tab on the connector? That could be preventing the connectors from getting seated properly...
obiwankabaldi
Lew
Rochester NY
Jeep Wrangler JL
The connector going to my headlight is a three prong (internal) but there are only 2 wires going into the connector. The adapter is a 3 prong and has 3 wires coming out of it. My Sport S was not wired for LED's and I am wondering about this. Any other Sport or Sport S guys add LED lights....?
weeitsmikelee
Michael
NYC
'18 Wrangler JLU; '15 Golf R; '15 XL883N; '82 CX500
I had to use two adapter harnesses (h13-h4 to h4-Molex) to get my lights working. I’m going to redo this and just splice the wires since my high beams don’t always work. Some photos of what you’re working with could help
JMONEZ
Jared
el dorado hills CA
2019 JLUR
Self employed
This all sounds so discouraging. My morimoto brackets and sealed 7 2.0’s arrive today! I have a sport S, I sure hope the connectors work correctly. What parts are needing to be modified in order to fit properly( cut or filled down) thanks y’all
bluesteeljl
CG
Miami
2018 Wrangler JL Sahara
I’m having a similar issue. Installed both lights and only low beams were working, nothing projecting in high beam mode.
Tried swapping out some of the connections to troubleshoot and then only 1 light would work. Identified that it is one of the drivers that doesn’t seem to be working. Can get both lights to work if I swap the drivers.
Called @theretrofitsource and they said to send an email with pictures and detailed description of my set up so am waiting on them to respond.
Found this video on YouTube which may end up being the solve to the problem but this definitely isn’t a straightforward set up.
obiwankabaldi
Lew
Rochester NY
Jeep Wrangler JL
I will be curious to find out if any of these fixes work. Wow. I never thought it would be that difficult to get a set of headlights to work.
obiwankabaldi
Lew
Rochester NY
Jeep Wrangler JL
JIMONEZ, I will be curious to hear how you make out. I do hope the work for you and if so please attach some pics so I can see what you did....Thanks. For starters my connector. (the vehicle harness only has 2 wires onto what is a three prong going to the headlights)
bluesteeljl
CG
Miami
Update: TRS believes it is due to faulty drivers so they asked me to send them pictures of them disabled and they have already sent out replacements. Will give it another try once they come in
JMONEZ
Jared
el dorado hills CA
2019 JLUR
Self employed
Morimoto sealed 7 2.0’s and adapter brackets just arrived, hopefully I’ll get them installed tomorrow.
weeitsmikelee
Michael
NYC
Can you guys post a pic of the adapters that come w TRS buckets?
Jim Marsh Chrysler Jeep
