Alternative solution to let Wolfbox not block sun visor
ym0bc1
ym0bc1
San Francisco Bay Area
JLUR
Which Wolfbox mirror and mount is this?
Mirror is G930, I think this is the only one with 10" length. Others are too long for the wrangler.
Bracket is the only one that fits G930 from wolfbox.
ASIN B0B53FTB6L
The button is dorman 76975. It works with the arm from the bracket kit.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
ObiMatt87
San Antonio, Texas
2024 Anvil JULR XR, 2018 Mojito Sahara JLU, 2018 Buick Enclave Avenir
USAF Active Duty (Retired), DAF Civilian (Current)
Glued the bracket slightly off centerline.
Also felt better as the mirror sits a bit farther away
You did a great job making it work, and that's about as clean as it would be with that solution, but I just don't want to jack up my OEM setup, even if I didn't have the adaptive cruise control box in the way. For many this will work just fine.
ym0bc1
ym0bc1
JLUR
I'm surprised you had to do that with a 10" mirror. I'm guessing it's a bit bigger than the one I have from another company.
Because of the shape. It’s narrower on top, which is running opposite to the sun visors shape. If it’s a top wide shape, I think it can do bigger screen
Ratbert
PNW
Software Engineer
OminousSkitter
The Ether
Trek Bicycle
The software would display up side down. So I prefer not.
If you don't mind, for sure that would work.
Every other mirror-style dash cam I’ve looked at (including a different model wolfbox I own) allows you to flip the image.
ym0bc1
ym0bc1
JLUR
WOLFBOX CAR LIFE
Summit Sponsor (Level 3)
Zhong
wolfbox.com
4xe
WOLFBOX OFFICIAL
