Jeff2018
- Jeff
- Sep 10, 2018
- Indianapolis
- 2021 JL Rubicon Unlimited EcoDiesel
HI Everyone,
I have an aftermarket bumper that is awesome. I had a little trouble today when removing the grill so that I could route some camera wiring around the driver side headlight.
With the bumper in place I could not remove the grill. I had to loosen all the bumper bolts (and remove two) so that I could slide the bumper forward about an inch. I'm curious if that is a common problem for aftermarket bumpers. It was hard to pop out the bottom clips with the bumper secured in place. I was able to get everything free. The problem was some parts of the grill could not clear the headlights without more room between the grill and the bumper.
It's not a big deal in this case. My concern is having to go through this in the future if I need to replace a headlight or something else that requires grill removal. And with the winch install I'm about do, it will make accessing the bumper bolts a lot more difficult.
Anyone else run across similar problems?
Thanks,
Thanks,
