IronScott
- Scott
- Sep 21, 2018
- NW Arkansas
- 2019 JLU Sahara, 1992 Jeep YJ, 2002 Chevy Silverado
I just installed a RK 3.5" lift that came with adjustable rear upper control arms, along with fixed front lower control arms, front and rear adjustable track bars. I got both axles centered and toe-in is a little less than 1/8". Front caster is about 5 degrees according to angle finder.
I'm confused about the rear, though. The instructions say this:
Recommended Alignment Specs are as follows;
3.5” Lift Height: 4.2 to 5.75 degrees of Caster with a .2 to .4 Cross Caster Split (.2 to .4 degrees more caster on the pass. side than the driver’s side.)
Tow: 0 to slightly towed in but within factory specifications
The rear pinion angle should be down 2 – 3 degrees from the driveshaft as shown below.
Using an angle finder I appear to be just a little over 2 degrees down on the rear pinion. Is this the only thing to be concerned with on the rear - that is, does this angle relationship handle rear caster as well? or is rear caster a separate thing or even exist at all?
I had planned on taking this to an alignment shop but I've heard that most shops won't adjust track bars or control arms. This is all new to me but if I'm good with my own measurements, I don't see the need in wasting time and money for a shop to check the toe.
The Jeep is riding really well.
