JeeJeep
- Apr 14, 2019
- California
- 2018 JLU Sport S
Thanks!Do you have a Fry's Electronics near you? They carry these resistors in stock and on their showroom floor. I can't recommend the other resistor as I have no experience with them.
I'm not using heat sinks and am only using large heat-shrink tubing/electrical tape. No heat issues with these that I've noticed (going on close to a year now).
I believe you'll be very pleased with your setup. It's highly recommended that you consider purchasing a small box (or two) of sound deadening material to line the stock enclosures. The jury is out on whether sealing the front enclosures vs. not sealing the ports makes a huge difference. They come ported, so I've removed the "ports" on mine and sealed the holes as best as I could. There's practically no way to seal the soundbar enclosures without building your own internal enclosure within the soundbar's speaker cavity. I've attempted to do so by lining and forming it with extra sound deadening material. As mentioned earlier, don't waste too much time/money on the soundbar.
I also recommend purchasing some foam rings (see your local audio store) to close the gap between the kick panel speakers and the kick panel speaker panel itself. This will help with sound/air leakage due to how the Jeep panels are configured.
Good luck with the install!
PS: Spotify is about the only streaming service I've found that will provide a higher quality sound stream. Make sure you have some high-quality music for your first twist of the volume knob! I highly recommend "You and your friend" - Dire Straits.
Will stop by Fry’s to grab some resistors/heat shrink tubing.. when I had the subs installed, the installers filled the sound bar with Polyfill and that got rid of that annoying sound bar/speaker rattle completely. Will get some of those foam rings too for the kick panels.
Thanks for the tip - will be sure to check it out Very excited to hear how it will sound - unfortunately my install appointment is about a month away so will have to wait :/
Another quick question - do you have experience with the FiX82 vs FiX86? One installer suggested getting the 82 and using the optical out to the amp to improve sound quality/tidy up wiring.. are there any drawbacks to using the FiX82 aside from losing the factory fader controls?
