ACC location in fuse box
Mwags
Abington,Pennsylvania
2018 wrangler unlimited JLU Sport S
I just put plug and play LEDs in my JLUS and it was pretty straightforward but it looks like I need to wires directly from fuse box for the DRL.....Was just wondering which fuse station I need to put the fuse tap into......I know it's the ACC but I can seem to locate it on the fuse box.....fuse location # would be great.......Thanks
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 991 911 / 2013 E92 M3
...huh?
Here's every fuse location/purpose/amp/size if it's of any help.
F01 Spare
F02 Starter 40 Amp Green Cartridge
F03 IBS 5 Amp Tan Micro
F04 Fuel Pump MTR/FPCM 20 Amp Yellow Micro
F05 Security Gateway 5 Amp Tan Micro
F06 Spare
F07 LTR Cool Pump — If Equipped 15 Amp Blue Micro
F08 TCM-8HP CYGNUS 15 Amp Blue Micro
F09 Spare
F10 KIN/RF HUB/ESCL 15 Amp Blue Micro
F11 UCI Port (USB & AUX) 10 Amp Red Micro
F12 HIFI Ampliftier 25 Amp Clear Micro
F13 Spare
F14 Spare
F15 IPC/SWITCH BANK-HD ELEC 15 Amp Blue Micro
F16 Spare
F17 Spare
F18 AC CLUTCH 10 Amp Red Micro
F19 Spare
F20 CBC 1-INTERIOR LIGHTS 30 Amp Pink Cartridge
F21 REAR WIPER 20 Amp Yellow Micro
F22 ECM/PCM/MGU WAKE UP/PPU WAKE UP 10 Amp Red Micro
F23 PCM/ECM 10 Amp Red Micro
F24 Spare
F25 MOD_SBW 10 Amp Red Micro
F26 CBC 2-EXTERIOR LIGHTS #1 40 Amp Green Cartridge
F27 Front Wipers 30 Amp Pink Cartridge
F28 CBC 3-POWER LOCKS 40 Amp Green Cartridge
F29 CBC 4-EXTERIOR LIGHTS #2 40 Amp Green Cartridge
F30 Spare
F31 DIAGNOSTIC PORT 10 Amp Red Micro
F32 HVAC CTRL MOD/SCL/OCM/DPDM 10 Amp Red Micro
F33 PTS/IRCM/AIRBAG DISABLE LMPS 10 Amp Red Micro
F34 ESC/EHPS/SBCM WAKE UP 10 Amp Red Micro
F35 BRAKE VAC PMP — If Equipped 30 Amp Pink Cartridge
F36 TRLR TOW MOD — If Equipped 30 Amp Pink Cartridge
F37 TRLR TOW CONN 7W — If Equipped 30 Amp Pink Cartridge
F38 ECM 20 Amp Blue Cartridge
F39 Spare
F40 DTCM/AXLE LOCK FT_RR 15 Amp Blue Micro
F41 IC/SGW WAKE UP 15 Amp Blue Micro
F42 PCR CTRL FEED (ESS)/SPARE (BSG) — If Equipped 10 Amp Red Micro
F43 PWR OUTLET (CARGO) BATT 20 Amp Yellow Micro
F44 IRCAM HEATERS 10 Amp Red Micro
F45 PWR OUTLET (CARGO) IGN* 20 Amp Yellow Micro
F46 AUTO HDLP LVL MOD/LVL MTR/HDLP SW 10 Amp Red Micro
F47 Spare
F48 Spare
F49 ORC 10 Amp Red Micro
F50 HD ACC — If Equipped 10 Amp Red Micro
F51 DSRC/USB/ISRVM/CSGM 10 Amp Red Micro
F52 CIGAR LTR 20 Amp Yellow Micro
F53 Spare
F54 Spare
F55 Spare
F56 IN-CAR TEMP SENSOR 10 Amp Red Micro
F57 Frt Drvr Htd Seat 20 Amp Yellow Micro
F58 Frt Pass Htd Seat 20 Amp Yellow Micro
F59 Spare
F60 CSWM (HTD STR WHEEL) 15 Amp Blue Micro
F61 LBSS/RBSS 10 Amp Red Micro
F62 Spare
F63 ORC 10 Amp Red Micro
F64 Spare
F65 Spare
F66 HVAC BLOWER MTR FRT 40 Amp Green Cartridge
F67 Spare
F68 Spare
F69 MGU (BSG) — If Equipped 5 Amp Tan Micro
F70 INJ/IGN COIL (GAS)/GLO PLUG MOD (DSL) 25 Amp Clear Micro
F71 Spare
F72 HD ELEC ACC PKG — If Equipped 10 Amp Red Micro
F73 PWR TOP LT 20 Amp Blue Cartridge
F74 PWR TOP RT 20 Amp Blue Cartridge
F75 PPU-BPCM & APM (BSG) — If Equipped 10 Amp Red Micro
F76 ECM (GAS)/PCM (DSL) 20 Amp Yellow Micro
F77 HTD MIRRORS 10 Amp Red Micro
F78 COMP/INTRUSION/SIREN/INTRUSION SNSRS 10 Amp Red Micro
F79 SMART BAR CTRL MOD 20 Amp Yellow Micro
F80 PCM 15 Amp Blue Micro
F81 REAR DEFROSTER (EBL) 30 Amp Pink Cartridge
F82 FUEL HTR — If Equipped 30 Amp Pink Cartridge
F83 GLOW PLUG — If Equipped 60 Amp Yellow Cartridge
F84 UREA HTR CTRL UNIT — If Equipped 30 Amp Pink Cartridge
F85 PM SENSOR — If Equipped 10 Amp Red Micro
F86 BRAKE VAC PMP 2 — If Equipped 30 Amp Pink Cartridge
F87 SUPPLY/PURGING PMP — If Equipped 10 Amp Red Micro
F88 NOx SENSOR #1/ #2 — IF Equipped 20 Amp Blue Cartridge
F89 SCCM/CRUISE CTL/DTV 10 Amp Red Micro
F90 TRLR TOW PARK LMP — If Equipped 20 Amp Blue Cartridge
F91 HORN 20 Amp Yellow Micro
F92 HD ACCY #2 — If Equipped 40 Amp Green Cartridge
F93 HD ACCY #1 — If Equipped 40 Amp Green Cartridge
F94 TPM/CORAX 10 Amp Red Micro
F95 Spare
F96 PWR MIRROR SW 10 Amp Red Micro
F97 RADIO/TBM 20 Amp Yellow Micro
F98 SW BANK-HD ELEC/OFF ROAD 10 Amp Red Micro
F99 Spare
F100 ESC-ECU & VALVES 30 Amp Pink Cartridge
F101 DTCM 30 Amp Pink Cartridge
F102 DUAL USB PORT 15 Amp Blue Micro
F103 HD ACCY #3 — If Equipped 15 Amp Blue Micro
F104 PPU COOL PUMP — If Equipped 15 Amp Blue Micro
F105 ICS/HVAC 10 Amp Red Micro
F106 ESC-PUMP MTR 40 Amp Green Cartridge
F107 TRLR TOW STOP/TURN LT — If Equipped 20 Amp Yellow Micro
F108 HD ACCY #4 — If Equipped 15 Amp Blue Micro
F109 TRLR TOW STOP/TURN RT — If Equipped 20 Amp Yellow Micro
F110 POWER INVERTER 30 Amp Pink Cartridge
F111 TRLR TOW BACKUP — If Equipped 20 Amp Blue Cartridge
Mwags
Mwags
Thanks..I saw this but am still unsure which location is for acc.
dsgrey
Kevin
2019 JLU
Wouldn't it be F92 and F93?
Mwags
Mwags
GWM4Tennis
George
Maryland
Jeep Wrangler Unlimited JL
Both F103 and F108 are empty in that a fuse just drops into the slots....no female connectors in those slots
Can you tell me this? If there is no relays, K17,18, 20 & 21 in my fuse box could this be why there is no power getting to my AUX switches? I already put fuses F50 and F72 which someone mentioned were the fuses needed but if I have no relays that would not allow the switches to function as well, am I correct?
melendez69
Marc
Waxhaw NC
...huh?
I put it in F52 cigar lighter slot..seems to work fine
That must've been some trial & error... Glad you got it done.
Now I need to check 103 & 108.... when I pulled them last week I didn't notice there were no female connectors.
Mwags
Mwags
Yes....took some trial and error..had to find one that came on when I started the engine and F52 did...Thanks
Mwags
Mwags
On that list it says "if equipped" for 103 and 108 so I guess my JLUSS is not equipped...Your JLR probably is.
