AC Inverter not working
discobean
Sydney, Australia
JLU
Hi all,
Is there anything you have to do to get the AC inverter in the back working? Mine just doesn't seem to supply any power.
Rubi D
Brett
Sydney, Australia
JL Wrangler Rubicon Diesel, Hella Yella
Hi all,
Just tested mine with a multimeter (Plugging in power cord to the inverter outlet. Tried both 3 pin and 2 pin cords. Apparently there is a safety switch in the connector which needs a power cord inserted). Output of 233VAC at either Accessories or Run. Haven't had to do anything to it, although the manual does indicate if the power rating of the plugged in device exceeds 170W the inverter may have to be manually reset. From other blogs, this just seems to be unplugging the device to reset the inverter.
discobean
discobean
Sydney, Australia
JLU
So 2 pin cord worked also? I only tested 2 pin
Rubi D
Brett
Sydney, Australia
Yes, both 2 and 3 pin cords worked, so the earth pin is not the switch.
Did you look for a fuse? F110, 30 Amp Pink Cartridge fuse is reportedly for the Power Inverter. I have heard of seating issues where fuses are not pushed in correctly from factory.
Joe98
Sydney
2019, 2 door Sport S, Mojito!
What model and colour is your Jeep?
Are you referring to the 12V outlet in the boot?
Steve F
Sydney, Australia
JLUR, JKU
The Rubicon and Overland have a 240V inverter built in, plug is in the back of the front console between the front seats.
