ABS light after lift
Number1olddog
Jason
Amarillo
21 JLURD
Just put an aev 2 inch spacer lift on my 392. I've installed 4 lifts total between 2 gladiators and two JLs and now this 392. There was no binding of any connections or brake lines when both axles were lowered. Nothing bound or pinched. Now I have an abs light on. I looked over the wheels speed sensors and all is good. Any recommendations?
I did have to take the rear passenger rotor off to let loose and reinstall the ebrake cable but all went back together fine. No binding when spinning the wheel off the ground. Cable works fine.
Number1olddog
Jason
Amarillo
21 JLURD
Forgot to add. Added jks control arm drop brackets and jks adjustable track bar to re-enter axle. Steering wheel set straight after lift
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
This is a lot easier to diagnose with data reported, can you get a reading of steering angle and wheel speed?
