6 speed manual trans adjustment
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
The issue I am having is when stopped I press the clutch and it will not go into 1st gear smoothly or any gear from a stop. No grinding, I have to put steady pressure and then it will go into gear. No issues while I am driving just when I am from a stop. It feels like the gate shift is not aligned. Is there any adjustments that can be done?
zakaron
Pittsburgh, PA
2021 Willys 4dr, 2004 Pontiac GTO, 1986 Honda Nighthawk S
This sounds like the clutch is slightly dragging like the pressure plate is not fully releasing. What you are likely feeling is the synchro on that gear match rotation speed due to the clutch slightly dragging. This will put early wear on the synchros if not addressed soon. Sorry to hear this :(
bllprk
Kalamazoo, MI
2008 WK CRD
I do agree with this. One thing that helps at a stop is to put the transmission in 2nd for a brief moment before shifting to first.
OEM or Aftermarket clutch? Any recent brake jobs? Anything recently worked on? Could be a bit of air in the hydraulics as well.
m3reno
m3reno
Sal
caldwell
No clutch or brake work. Seems to be getting worse.
zakaron
Pittsburgh, PA
I would bleed the clutch hydraulics as a first step just to make sure there's no air in the line. Any air in the line can cause less travel of the clutch fork that the release bearing has to push against the pressure plate. It is an easier first step than pulling the entire transmission.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Check your cables, that procedure posted above might help. But it does sound like the clutch is not releasing, either air, a leak, or physical defect with the slave cylinder. With the active recall, you should really take it to the shop if this is getting worse.
m3reno
m3reno
Sal
caldwell
yes, that's my next step.
