500% brighter?
JSFoster75
Bluff City, TN
An update on my install, I got the DRL portion of this light wired to a switch on my trigger six shooter wireless switch system. One of the lights quit working after less than six hours. I have ordered a replacement from Amazon that should be here sometime this week. The turn signals are working fine on both, and I checked all my power connections to make sure that power was still going to the light itself. Fortunately I ordered additional fender clips so I won’t have to wait on those as well.
Replacement arrived and they've been installed for a few weeks no with no problems.
JSFoster75
Bluff City, TN
I ended up wiring the DRL to a switch on my Trigger Six Shooter plus so I could turn them on/off whenever I wanted to.
Another note, I had to replace the drivers side because the DRL (White) light failed after less than 2 hours of usage and only 12 hours on the Jeep...
Update on these lights... I just had my 2nd light quit working... I have contacted Gempro through Amazon to see if they will replace it (again)... So far, I'm very unimpressed with the quality on these...
DanFelix
Riverside, CA
2018 Wrangler JL Sport S, 3.6l
I have a set sitting in the garage, waiting for install. You have convinced me that I can live without them. Thank you.
jmccorm
jmccorm
Josh
Tulsa, OK
2021 JLUR
Systems Engineering
Unfortunate. Possible workaround if you have a JScan: turn down the voltage. (Not ideal.)
I'm sorry that these aren't working out well for everyone.
