3rd brake light with 285s
bharvey88
Brandon
Oceana, WV
2019 Jeep Wrangler Unlimited Sport S
With 285s do I need to do anything to the tire (deflate?) and/or 3rd brake light?
jludave
The Isle of Long
IT Manager
With 285s you'll need a spare tire relocation bracket on a Sport S. You will also need to raise the 3rd brake light.
XJfanatic
El Paso, Tx
2020 JLU, 2020 JT, 2000 TJ
I had the opposite experience on my sport. I have 295/70r17. I did nothing and everything fits fine.
To the OP are we talking 285/70 or 285/75? With 285/75 you may have to do the above depending how true to size they are.
AdamG
Adam
SE Michigan
2019 JLSportS - SOLD; 2026 Moab 392
I had to trim the rubber bump stops but otherwise did not need to raise the 3rd brake light or do anything else
To get those bump stops on/off, it’s easier to push/pull from the inside by taking off the inner tailgate panel
Nomad
Ron
Northern VA
2018 JL Sport S
At first I made no changes. Then the next time I rotated my tires I raised the brake light. Now I notice the rear wiper arm is contacting the backside of the brake light bracket. Next rotate I'm going to lower it again.
