Florida 3D printed switch panel
loydd24
loydd24
Justin
plant city, fl
2019 JLU Sport
Just to clarify (I am a little slow at times, so please bare with me), do you make one that fits a 2020 Wrangler Sport S with 5 red switches unpainted? I looked on your Etsy site but did not see that specific option.
Also, You mentioned earlier in this thread that you have a "no drill" option. Do you use 2-way tape to secure the plate to the cubby?
Thanks in advance. BTW, excellent work! I wish I was as talented and insightful as a lot of you guys on this site. :rock:
Yes I make one that replaces the full cubby, there’s a bracket that bolts in to the back of the dash and the switch plate slides in from the front of the dash and bolts into that bracket. I do have silver switches with red LEDs but the supplier switched the pins around on the switches so I don’t have a harness for them but they do come with female spade connectors. The black switch with blue leds come with a pigtail harness that makes wiring them easier.
Jeep Wrangler JL 3D printed switch panel DAE69ECF-E04B-45D0-AD0E-A776866DB19B
this picture shows the bracket, the full cubby bracket is the same concept.
Jeep Wrangler JL 3D printed switch panel DF9D783A-A1FA-4D24-BB0F-E02F009C26DD
this picture shows the panel mounted to the bracket with Phillip bolts and nuts.
Toxiclows
Christopher
2020 Willy’s jl
I am also interested in buying the STL file from you, MY parts manager at work has a 3d printer and wants to make this for me. pm me. as well. . .
thanks. Chris
loydd24
loydd24
Justin
plant city, fl
2019 JLU Sport
thanks. Chris
Unfortunately I can’t sell the STL until I get the patent for it, but you can purchase it here if you’re interested.
https://etsy.me/3j07mSA
drrobinson
Evergreen, CO
2021 Wrangler Unlimited - Willy’s - White
Could you make one for the half cubby on the left side? I have A Willys with AUX switches on the right and cubby on the left.
I just need it blank so I can install a brake controller knob (Redarc) and two mic panel connectors (RJ45)
loydd24
loydd24
Justin
plant city, fl
2019 JLU Sport
I’ll try to get that drawn up this week and get back with you
04MachMan
Alan
Weatherford, TX
2021 Wrangler Willys
I would be interested in a blank one for the left side as well. Be a great place to mount switches for aftermarket seat heaters.
drrobinson
Evergreen, CO
Just following up to see if you have had a chance to get to this?
4xFUN
Scottsdale AZ
2024 2-door Ruby-X, 2020 2-door Ruby, 2023 RAM TRX
Would anyone be interested in this switch panel? It would be painted satin black and the material is PETG which is temp resistant up until 185F. $30 raw, $50 painted, $70 painted with switches installed. They will come with necessary hardware. Only modification required would be to cut the back of the cubby out to run wire and to bolt the plate in place, the bolts utilize factory holes so no other holes are required. **Edit: I’ve got a new design that requires no cutting or drilling for the full cubby and half cubby for those with Rubi’s or Mojave’s. I’ve also started using ABS as it’s a little stronger and more temp resistant.
Very nice!!
Any chance you can do anything to laser engrave / replace factory AUX switch bank with custom lettering?
ShafferNY
Ticonderoga, NY
Current Jeeps - 2019 JLR, Hella Yella, 2026 JLR Reign
How much are you asking for the half panel? I need one. Thanks
loydd24
loydd24
Justin
plant city, fl
2019 JLU Sport
I did make one and sorry for the late reply, but I have not heard back about the fitment yet so I would hate to sell one that doesn’t fit. I’ll reach back out and see if I can get an update.
loydd24
loydd24
Justin
plant city, fl
2019 JLU Sport
Very nice!!
I did actually just get a laser engraver but haven’t set it up or taken the classes for it just yet. I’ll see what I can do with it and if I learn it quick enough I’ll let you know.
4xFUN
Scottsdale AZ
That would be cool and I'm sure lots of other forum members would take advantage of your services!
drrobinson
Evergreen, CO
Great. Standing by.
