loydd24
- Justin
- Sep 27, 2020
- plant city, fl
- 2019 JLU Sport
Would anyone be interested in this switch panel? It would be painted satin black and the material is PETG which is temp resistant up until 185F. $30 raw, $50 painted, $70 painted with switches installed. They will come with necessary hardware. Only modification required would be to cut the back of the cubby out to run wire and to bolt the plate in place, the bolts utilize factory holes so no other holes are required. **Edit: I’ve got a new design that requires no cutting or drilling for the full cubby and half cubby for those with Rubi’s or Mojave’s. I’ve also started using ABS as it’s a little stronger and more temp resistant.
