3.6 ETorque Whine
New Jeeper
NY
Willys
Anyone have a constant whine coming from the belt area of their 3.6L etorque? I just got mine (200 miles on it now) and it has a constant whine to it. It is a different noise than when you turn the steering wheel and the steering pump makes the electric whine noise. It is not a very loud whine, but I can hear it through the passenger fender opening, under the car, and in the hood area. Thanks!
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
I am experiencing what appears to be a similar sound. I have always just assumed it’s the generator that replaces the alternator. I’ve had the sound from day 1. I now have 1500 miles on it and it still sounds the same.
DanW
I have not noticed this on my wife's Etorque. I'll give it a drive asap to see if something stands out. But I'd bet I would have noticed it. I'd have that checked. With the quick response from @JasonInDLH with a similar experience, I'd bet it is a common issue and there should be a quick fix for it. You could drive another at the dealership to compare, too.
New Jeeper
NY
Willys
I got under mine and was listening closer. It appears to be coming from the passenger side near the belts/pulleys. I wonder if it is a pulley or the belt. Again, only 200 miles on it so there should be no whine.
DanW
I just asked my wife and she said she's not noticed anything at all. She said it is just smooth and quiet, as it should be.
Twist
Georgia
2022 Jeep JLUR
My 2022 JLUR XR makes a high pitch electric whine. It's not super loud, but I have noticed it. I can really only hear it as I am pulling into or out of the garage.
I figured it was something on the belt system, or electric steering pump. I haven't investigated as I assumed it was normal.
3.6 etorque btw...
New Jeeper
NY
Willys
Thanks. The high pitch electric sound is your steering (electric). Totally normal. Makes a noise when you turn the steering wheel and then goes away about 5 seconds later. The noise I am referring to is a different noise. But thank you for the comment!
Gaspare
Gaspare
Va
2021 JEEP JL RUBICON EXTREM RECON
I have a 2021 jeep rubicon extreme recon 3.6 e torque. At 19k Mile I started getting drivers side at cold start sound like a engine ticking noise. Went to dealer they said it was paper stuck to fan belt. Replace one belt still noise then replaced other belt noise still there. I told them they were wrong from the first belt that they change. Went to other dealer they opened up a case with jeep tech. The new belt had to be replace with in a week They then replaced AC pulley noise still there. They replace harmonic balancer. Noise still, now that the weather is warm noise still.
I hope someone can help me out.
jo_xj
MO, USA
2000 Jeep Cherokee XJ
2023 JLU Willlys 3.6 eTorque here. No noticeable whines except for the steering.
Gaspare
Gaspare
Va
