3.0 Block Warmer Cord Install
Gomer Pyle
JD
DFW Texas
2021 Sarge JLUD Willys 3.0 Ecodiesel w/SOT, Cold Weather, Alpine and Tow Pkg
With winter arriving I thought I'd install a block heater cord on my 2021 for trips to CO mountains this ski season. I pulled the factory plug/cover off the inlet and had my cord routed the way I want it and could not seem to get the cord's plug 'seated' on the fixture? What a bitch to get into place and place into the receptacle...I was on my back and 'blind' to it but made it work. I just wasn't happy with how easily it could pull back off after I got it installed/seated as much as I could. Anybody else have this experience...there's no final snap when the plug fully seats???
BDinTX
Dallas, Tx
Gomer Pyle
Gomer Pyle
JD
DFW Texas
May be a dumb question but are you sure you have a block heater installed? I ordered my 2021 and a block heater wasn't an option.
In contrast, my old RAM trucks with the Cummins came with block heaters installed from the factory and adding the Mopar block heater option only got you an overpriced cord.
Couple of pics here:
https://www.jlwranglerforums.com/forum/threads/diesel-engine-block-heater.87253/post-1821383
No, I pulled the protective cap off the receptacle and it's there...it's unmistakable. I'm just not happy with how 'seated' it is once installed. Might bounce right off the pins in rough conditions...
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
For at least a while, all diesels were getting the block heater installed. Selecting it as an option got you the cord. Not selecting it got you no cord.
Gomer Pyle
Gomer Pyle
JD
DFW Texas
wish there was a fastener of some type to 'lock' it in place on the pins...thing just slides back off pretty easily with a slight tug
Compression-Ignition
Roy
Montana
'22 JLUR 3.0 Diesel, '20 6.7L F350, '94 12 valve
It’s probable that you’ll only get peace of mind if you take off the tire, remove the inner fender, and then watch and feel the insertion from a better vantage point. I.E. looking at it straight on.
cnapierala
Florissant, CO
2022 Wrangler JL Rubicon Diesel
Engineering
Oh goodness! Yes!!
Gomer Pyle
Gomer Pyle
JD
DFW Texas
Haha, what are we talkin' about, again?
Gomer Pyle
Gomer Pyle
JD
DFW Texas
I believe I had it inserted / seated all the way...it just seemed to pull back off too easy for my liking so I put the OEM plug/cover back in and am re-thinking. Yeah, I'm weird like that...
