2022 rubicon diesel firewall
Lp5151
HB
Oregon
2022 Rubicon JL diesel
been trying to find a place to run a wire harness for a set of running lights thru the firewall. can't find any access points. don't want to drill. should be a grommet or 2 somewhere. not sure if the diesel blocks these access points? can any body tell me where to look? or what the secret is?
21JLURDG
Bill
Olympia, WA
2021 Wrangler Unlimited Rubicon 3.0 Gecko
I ran my ARB compressor wiring along the wiring harness behind the glove compartment. It comes out behind and below the battery. It's been a while but I think it was easier to access by moving the inner wheel liner back.
RicRecon
Ric
NorCal
2021 JLUR 3.0, 2021 JT Overland 3.0
There’s a grommet just below the coolant reservoir on drivers side. It’s about 2” in diameter and has small tabs which help.
I used this to run my wiring for my BLUETTI Charger 1 cables and it works great for that purpose.
kickingaz
New River, AZ
2022 Rubicon 392 XR
I am assuming that you do not have the factory AUX switches, correct? If you do, this wires are near the battery.
Lp5151
HB
Oregon
Have the auxiliary switches, but the light harness has a 2 position switch for high and low beams, so need to run harness with that switch.
wwtucson
William
Thousand Oaks
2023 jeep wrangler Rubicon
This is what I used for my HAM radio antenna wire.
rickinAZ
Rick
Phoenix
2026 MOAB 392
What he said. @Lp5151 picture a straight line from your left knee forward through the firewall. It’s partially blocked from view from the engine bay; I spotted it easier from below the dash
Lp5151
HB
Oregon
Thank you
