2019 T/Map Sensor
miseo
OK
2019 Jeep Wrangler 2.0
2019 2.0 had it go into limp mode and throw a P006D code. I was going to clean the T/Map sensor while I wait for new one to arrive to see if it fixed it and I ran into my problem. Right above the T/Map is a solenoid valve mounted on a bracket. In order to get to the Tmap bolt I need to move this from what I can tell. To remove this I would need to remove some lines etc. this appears to be the only way to me, but I wanted to see if anyone else has removed this before and found a better way to do this?
