2019 2.0 heater problem
Duke4Life
Lewis
South Carolina
2019 Jeep Wrangler
Heater blows out hot on the driver side, cold air on the passenger side.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
If you hold the temperature adjustment button and sweep all the way from LO to HI and back, can you hear the change in air flow on the passenger side or no?
Duke4Life
Lewis
South Carolina
2019 Jeep Wrangler
I’ll have to check that tomorrow. My son is driving it now. But I’ll definitely check and reply. Thanks
Duke4Life
Lewis
South Carolina
2019 Jeep Wrangler
Ok. Still trying to figure out this heat system problem. It’s not any if the 3 actuators, they’re all working. It seems like they do whatever they want to do, not what you set them to do. I’m thinking it’s a problem with either the radio or the control panel under the radio since both of those can adjust the settings. Uconnect website says all the updates are already installed on the radio. Surely someone else has had this problem.
Duke4Life
Lewis
South Carolina
2019 Jeep Wrangler
I typed my vin number in on uconnect website. It says I have the latest update as I stated already.
mwilk012
Oklahoma
Service
Don’t care. Reflash it.
And by reflash it, I mean take it to the dealer and make them fix it.
If software doesn’t fix it, the control head is bad.
Duke4Life
Lewis
South Carolina
2019 Jeep Wrangler
Ok. Is this a known problem they have with these Jeeps?
Duke4Life
Lewis
South Carolina
2019 Jeep Wrangler
I’m asking, has there been a recall? It’s hard to deal with any dealership unless it’s a recall item.
Beachcomber72
2022 JLU High Tide
At one point in time on the early JL’s up to mid 2019 there was an issue with the passenger side blend door actuator. Not sure if that relates to your issue. Easiest as mentioned would be the software update if it’s applicable to your situation.
Beachcomber72
2022 JLU High Tide
No recall that I have ever seen that doesn’t relate to a vehicle safety issue only. Otherwise it would fall under a TSB.
mwilk012
Oklahoma
Service
Recalls are for safety failures only. Your specific vehicle has a specific problem. You can’t fix it yourself. It has to go in.
Duke4Life
Lewis
South Carolina
2019 Jeep Wrangler
Ok. Thanks y’all. I’ll contact the dealership tomorrow. I can watch the actuators move as I change the settings, but they don’t move every time, just sporadic. And the heat blows out on the drivers side, cold air on the passenger side. I can change the position from floor to vent, sometimes it’ll move but sometimes it won’t. It’s like they’re all in a confused state. Lol. At least I’m in one.
Jeeper dad
Dustin
South Carolina
2020 JT, 2022 JLU Sport Altitude
IT, Girl Dad
If you’ve got dual zone climate control, do you have one side set cooler than the other? Stupid question, I know, but could be something obvious that was overlooked.
