2018 Wrangler JL new issue
Liquidlemur
Ed
Louisville, Kentucky
2018 Jeep Wrangler JL Unlimited Sport S
Management, Engineering
So, my 2018 JL is starting to have a couple of issues. For the past 2 to 3 weeks I've been having what feels like a misfire to me. I have the 3.6 motor and 66k miles on the Jeep. It starts and idles perfectly. When I press on the accelerator it seems to hesitate just enough to be noticed. If I punch it, it seems fine. It also seems to cut out / misfire when I ease off the pedal to maintain speed. I'm trying to get it into my local dealer, but they are swamped and it could take up to a month to fix. Anyway, I've talked to other JL owners and have been told a different story by each one. So far, I've been told it's the crankshaft position sensor, or the TPS, or the entire throttle body, or a bad / clogged injector, or fuel pump, and finally...spark plugs. No CEL and I can't check for codes because of the security module (unless I bypass it).
Also, two days ago my AUX battery failed. I did get a CEL and the start/stop light on that one. I isolated the AUX battery and pulled the fuse. That fixed that issue. However, I am not sure if the other issue is related.
I'm not an expert mechanic by any means, but I'm usually able to fix things if I'm pointed in the right direction.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Nobody is pointing you in the right direction by guessing at different parts with nothing but a slight, intermittent hesitation as a symptom. Do you have any engine data to check or is it 100% guesswork?
Liquidlemur
Liquidlemur
Ed
No engine data. I'm hoping to dig deeper this weekend. The hesitation was worse coming home tonight though.
