2018 Rubicon Suddenly Overheating Uphill
Countryswiss
Countryswiss
Devin
2018 Jeep Rubicon Unlimited
The AC condenser is in front of the radiator. Just because it’s clear doesn’t make the radiator clean. Take the plastic cowling off over the radiator and make sure leaves or road debris is not between the 2 Impeding the air flow.
Will do, I am planning on also removing the entire grill for better access to the radiator as well. Any other tips for reaching it?
Countryswiss
Countryswiss
Devin
In Texas. Lot of clay there. My bet is on a dirty radiator.
I actually just moved here a week ago, Noticed the overheating issue during the 1500 mile drive over. We will find out tomorrow though
Countryswiss
Countryswiss
Devin
Update
I sprayed out the radiator from the engine side and straight chocolate milk came out for about an hour. I got what I could with the fan in the way but I am going to remove the fan in order to get the rest of the radiator.
It seems to be running a bit cooler but we will see what ends up happening as I drive it more and how it runs once I clean out the rest with the fan removed
Any tips on removing the fan?
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Update
Do a quick search for one of the radiator replacement threads, it has every detailed step from the service manual in it. Replacing the radiator is pretty cheap, if it won’t clean up.
https://www.jlwranglerforums.com/forum/attachments/cooling-fan-removal-diy-pdf.533846/
Countryswiss
Countryswiss
Devin
Countryswiss
Countryswiss
Devin
Well folks the updates with be temporarily paused as my jeep was hit while parked outside a house. Only a scratch on the fender but the suspension is so damaged it isn’t drivable. I’ll keep y’all updated
garykk
Gary
Southern NM
2022 JLURD
Damn, a clear road and they hit you!!!
