Rogue321
- James
- Jul 26, 2021
- Colorado Springs
- 2018 JLU
Had a strange issue happen today. I pulled into a gas station for a break. Jeep sat there for 15-20 minutes or so. I got in to start it, and it sounded like the starter would just randomly bump, but not crank. The dash lights and gauges was doing all kind of stuff. I kept trying and after several attempts, it started (cranked perfectly once it cranked). I turned it back off and tried it again and pretty much the same sequence.
It did start the second time as well. I drove it a little ways down the road and parked it. The ESS light was on, the outside temp gauge read 150 degrees, and a single red dot lit up on the tachometer. I have no idea what that light was. It doesn't show up when I am in accessory.
I left it there for a bit and came back a few hours later to see if I could get it started to get it back home. Started fine. I turned it off and started fine again. I drove it home, turned it off, started fine again. ESS light is on, but everything else seems fine.
I'm guessing it's probably one of the batteries, but once it cranked, it cranked normally. Cranks normally now.
I'll try to get it into the dealer tomorrow, but curious if any have experienced this, or if there's a tech bulletin describing this behavior.
