2.2 Oil Pressure Readings
challenger23
England
Euro Spec JL Rubicon Diesel
As you know the Achilles heel of this engine is the small seal that connects the sump to the bottom of the crank case. I have preemptively changed mine with a JTD upgraded part. Im interested to know everyone’s oil pressure under maximum acceleration. Mine seems to top out at 60 psi. It seems to not go a single psi over 60. I would be interested to know other peoples figures.
Donkeyshot
guillaume
Belgium
jeep wrangler unlimited night eagle
Mine never gets over 3.2 Bar (46psi). 60 psi seems a bit high? It is my second 2.2 and both never got over 3,5 bar. Never had issues with the seal. I have over 100 000 kms on it now.
challenger23
England
Low oil pressure seems to cause more issues on this engine than too high. The Stelvio 2.2 runs closer to 80psi when on full throttle. I’ve had the JTD seal mod which should help. My local dealership said between 3.3- 5 bar for full revs.
TordFuglstad
Tord
Norway
Jeep JL 2.2D
Nice info! Do you have a link to the part? And how complicated is the install?
TordFuglstad
Tord
Norway
Jeep JL 2.2D
bmbelo
Bruno
France
JLUR 2018
Was just looking for this same part for my Jeep when I stumbled upon this topic... Getting it as well even though no signs of oil pressure issues. Wondering if we can apply it to our sumps...? I guess so....? 97kkms and going.
TordFuglstad
Tord
Norway
Jeep JL 2.2D
You have the 2.2D?
bmbelo
Bruno
France
JLUR 2018
I do yes, from 2018. I live in France.
goborgen
Geir
Norway
JLU Rubicon 2020 2.2.l Diesel
What pressure do you all get att idle with warm engine?
FedeWrangler
Federico
Italy
www.instagram.com
Wrangler Rubicon Recon 2020
Now that I've made this modification this post, the minimum pressure is 1.8 bar when the engine is warm. When cold, it's 2.1/2.2 bar, and when accelerating, I can easily reach 4 bar.
goborgen
Geir
Norway
Hmmm. Mine is 15-16psi, which I belive is just around 1-1.1 bar. Hope the pump isn't getting bad. Just changed the seal in the sump, but didn't make a difference. Had one incident of low pressure warning earlier this summer, but don't know how low it was then.
bmbelo
Bruno
France
JLUR 2018
Same here, when REALLY hot (south EU, PT-ES), ENG oil ~115 °C, it gets 1~1.2 at idle. I'm using Liqui Molly 4130 0w30. Getting the aluminium thinga majiga w/ the orings installed next week.
