12V Fridge & freezer
@OUTDOORTREE
Bob
Yakima, WA USA
2018 Rubicon JLU
Hey Bob, unless you've rewired things from the factory--not my first guess--your cooler's, we must both agree, taxing both the (I'm assuming 3.6L) JL's batteries: main and ESS/Aux, which are (and because they are) connected in parallel nearly all the time.
(When not is a discussion for another thread.)
This said sir, I'm going to assume your not charging your batteries by running the engine--so--do you have like, a trickle charger going or something to address the cooler's electric draw?
Cheers.. : - )
I am running off the stock wiring - and yes, 3.6l. The Dometic fridge can since the Jeeps battery levels and shuts off if the the Jeeps battery levels drop to a certain point. Seems like after about 2 days the fridge slows down.
KDB
WI
2018 2 Door JLR
My 37 ARB does the same, monitors the battery levels and will shut itself down if battery gets too low. That said, i have never had to worry about it, even when I did a rim to rim in the grand canyon it sat for 2.5 days, jeep started right up and all food was still cold.
Jeff1
CT
2019 JLUR
We used the arb wiring with our snomaster cooler. It’s 8ga and designed to be ran from the battery. We did that and mounted the plug in the cargo tray under the cool. Drilled a small hole for the plug and it’s tucked out of the way. Works great. The rear plug will work (kinda). There’s a bunch of loss in the factory wiring.
Brett
I have the ARB wiring kit out of my JKU, am planning on running it to the aux panel one of these weekends, but until then i'm going to use the factory 12v plug in back.
zb39
earth
2018 Ram 5500, 2018 Durango GT AWD, 2015 malibu, GMC 3500 Dump, 70 challenger convertible, 2019 2 door rubicon, manual tranny
I use ARB and ran the wiring kit from the second battery. I have a genesis dual battery set up. ZERO issues. It is always in the jeep.
Jeep Wrangler JL 12V Fridge & freezer IMG_0334
Jeep Wrangler JL 12V Fridge & freezer IMG_0361
sjl136
New England
'24 Willys 2dr, ‘90 YJ, '22 4Runner
Finally put in an order for the ARB 37QT Classic Series II. Dometic, Engel and SnoMaster were the other finalists. I also just ordered the FlexoPower Lithium 444 battery pack, and will run the fridge from there most of the time, and connect the 12V cargo area plug to the FlexoPower to charge that while driving/ wheeling. I wanted the back up power supply to have the option to use it for camp lights, charging electronics, possibly even a small fan or two on summer nights in the tent. Plus I will use the fridge in the Jeep and the family SUV, so having the lithium pack alleviates battery worries for when we tailgate or leave the fridge in the SUV for periods of time. The lithium pack will also be handy for power outages, and provides a starting point if I decide to add a solar panel down the road. I should have ordered these things earlier. I will be shocked if the fridge shows up before the next Jeep camping weekend in 6 days, so it might be one last trip with the cooler. Here is a link to the FlexoPower if anyone is interested: https://www.flexopowerusa.com/products/lithium444
Jeep Wrangler JL 12V Fridge & freezer LiPo444
D60
CO
JL
The Milwaukee M18 fan will run a surprisingly long time on a 5.0, and of course even longer on a 9.0 or 12.0
But, nice!
javelina
WAFB, Arizona
2019 MOAB "Saharacon", 2006 Wrangler TJ, 2018 F-150 RCSB 4x4
I'm kinda liking that power supply. Especially since I use a CPAP. This could really re-open some camping opportunities. thanks!
intentsrig
JLU Sporticon
How long will that thing last powering the fridge?
sjl136
New England
I haven't run the fridge solely off the power pack for more than 24 hours, but I estimate it will run it for at least 48 hours. I have the Jeep charge the power pack while driving around and we aren't usually stationary for more than about 12-15 hours max.
brewskisteve
Oceanside, CA
2018 JLU Rubicon, 2001 Ford F350 4x4 crew cab 7.3L diesel
Does anyone have an opinion on Costway? I don't where I found a conversation on this but I logged it a way a few weeks ago
https://www.amazon.com/dp/B07CG4Q1YJ/ref=cm_sw_r_other_taa_Dx0qCbZ50WPN1
I just saw your post about the Costway Refrigerator Freezer. I purchased the 54QT about three weeks ago. Needed a second fridge for beer when large family stayed over weekend. I left it plugged into 110 and played with the low/med/high settings and it worked great holding around 55 beers at around 36 degrees all weekend. I moved it to my JLU using the rear DC plug and drove around for a day stopping for errands and it worked perfectly throughout my trip. Now it's sitting on my Sailboat running on the DC plug with no issues. I changed the settings to EVO so as not to drain my batteries and haven't noticed the battery charger working any harder then normal. I couldn't justify the cost of the ARB, Dometic, Engel, etc. I did buy the five year warranty through Amazon for extra protection, that brought total cost to around $535.00. So far I'me very impressed by this unit and it looks identical to the ARB 54 QT unit, just different colors. ARB's thermal bag fits great on it according to other posts I'e read and Jeepers recommend getting the ARB DC charging system with locking capability so the plug doesn't come loose during rough trail use. I hope this helps you out.
intentsrig
JLU Sporticon
Nice. I have been reading a lot of mixed reviews about it. Some people said they were only getting 6 hours max out of it. Been looking at a brand called jackery. Similar price for their 290 and it has about 21ah. Similar solar panel features etc
brazos
2018 JLU Sport, Giant singlespeed mountain bike, Hobie Revolution kayak
Dog Feeder
I’ve been led to believe that a “Danfoss” compressor is key to low power draw, and perhaps to long-term reliability.
I know ARB, Engel, and Snomaster use the Danfoss. They also have impeccable reputations.
In my research, I never saw a negative comment about any of them.
That in itself is remarkable, given the nature of the Internet.
Battery life and long-term reliability are FAR more important than initial fridge cost to me, given my lifestyle, though.
That’s why I only considered the 3 brands I did.
  • Like
Reactions: KDB
brazos
Dog Feeder
To each his own, but instead of power packs or more batteries, I’m going to rely on my Honda 2kw gasoline generator.
It weighs about the same as an additional battery (46#), and will never go dead.
It’s bigger than a battery, but far more versatile and dependable, imo.
And I can’t accidentally run it down and be stuck, as I could with any number of stored power devices.
If I’ve got gasoline, I can make electricity and charge batteries.
And unlike a battery, it will still work when my grandchildren pass it on to their grandchildren.
Honda small engines run forever.
intentsrig
JLU Sporticon
I agree for sure on the versatility and usually much longer lasting but the weight of these new power packs are much much lighter than 46 pounds. Most are very small lithium 9x5x7in and weighing only 6lbs. I can put that under my seat.
DanW
You are right about the danfoss being the key to low consumption, and the big brands use them while some Chinese brands use copies of them. Snomaster, however, doesn't use the danfoss. They use their own. They'll use danfoss compressors in some units that they make for other brands, but they claim theirs is better and they warrant them longer. The LS35, for example, has their compressor and has a 7 year warranty. I think most of their fridges have a 5 year warranty.
I'm not knocking the danfoss compressor. It has a great rep because it has earned it and performs very well.
