WontonJLUR
- Matt
- Dec 26, 2018
- Suffolk, VA
- 2019 JLU Rubicon
- Build Thread
- Link
Updated to reflect all currently installed stuff:
Axles: Fusion 4x4
-Shaved 14b rear
ARB air lockers
5.38 gears
1410 yoke
40 spline shafts
72" WMS
-Kingpin 60 front
ARB air lockers
Yukon super joints
72" WMS
Rear brakes:
Range Industries electric parking brake conversion
Suspension:
RPM Steering 3 link front, 4 link triangulated rear long arm.
Motobilt adjustable upper mount for adjustable geometry in rear
Steering:
Fusion drag link
RPM Steering offset heim tie rod
PSC Electric pump, XD steering box, hydro assist
Wheels/tires:
17” MR108 beadlocks 3.5BS
42" non sticky treps
43" journey rock poison sticky tires
Armor:
Genright rear corners
Motobilt weld on sliders
Motobilt Tomahawk frame chop bumper
Rear bumper removed, VKS D ring mounts bolted to rear frame
JCR offroad Front and rear half doors
Cage:
Motobilt JLU cage
Seats:
PRP Enduro Trek fronts
PRP Enduro Elite bench rear
PRP Harnesses
2019 JLUR w/ automatic trans
58k miles with several thousand off-road at various places across the east coast.
Jeep has always been primarily rock crawling focused and trying to find the hardest stuff that we could at every park. Spent the first 30k miles on 37s w/ Metalcloak 3.5 game changer lift, then got BFG KM3 39s at 30k and have run them since.
The stock axles have held up very well (edit: realized I lied and they have the Dynatrac HD ball joints installed, but are completely stock otherwise) and honestly they’ve performed great. I’m very judicious with the skinny pedal and try my best to avoid bumping over obstacles unless completely necessary and I try to minimize wheel speed. Between that and, I’m sure, a healthy bit of luck, these stick axles have served me very well.
the beads on these tires are so thick that I fought for about 2hrs trying to get them in manually, and eventually decided to try using the Jeep to gently apply force to pop the wheels in. Worked out great!
Axles: Fusion 4x4
-Shaved 14b rear
ARB air lockers
5.38 gears
1410 yoke
40 spline shafts
72" WMS
-Kingpin 60 front
ARB air lockers
Yukon super joints
72" WMS
Rear brakes:
Suspension:
Steering:
Fusion drag link
Wheels/tires:
Armor:
Cage:
Motobilt JLU cage
Seats:
PRP Harnesses
