‘23 4xe 4 leaking shocks
Smccray
DFW
Hydro Blue 4xE, 200 series Cruiser, GX460, Q7
searched a bit but I didn’t find anything.
Took my 4xe Sahara in for service and the dealer found all four shocks leaking. They have the front pair, but the rear shocks are apparently backordered at the moment. Anyone know anything? Is this a common problem or am I just unlucky? Some reason shocks are back ordered?
thanks!
Steemax
Los Angeles
2022 Rubicon 4xE, 2025 Outback Wilderness
There was just another thread this week with someone else with Rubicon shocks leaking. It's so common that if you purchased the vehicle I wouldn't even bother getting the free replacements under warranty because it's just going to happen again. Unless you don't mind trips to the dealership.
I'd go with a quality OEM replacement with one of the entry level Bilstein's or Fox shocks. Ranchos should fair better.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
If you are staying stock, you can probably get some take offs from someone local for like $50. Either forum/facebook or a local off road shop.
Smccray
DFW
Thanks!
time to do a little research. Not sure what I want for the best on road manners of the wrangler. I won’t do anything off road more aggressive than logging roads.
Steemax
Los Angeles
Thanks!
I have a 4XE as well and have been enjoying the Bilstein 5100’s both on and off road though I’m not sure how much you want to budget for shocks, the 5100’s can be had for under $100 a corner on sale.
They are known to be on the stiff side but I think the weight of the 4XE makes them ride more like Rubicon shocks.
Smccray
DFW
I don’t know how much I need to spend. It isn’t a primary vehicle for me, but I want it to ride well. How much should I budget? Is there a need to replace springs too?
I need to do the same research for a 2014 landcruiser. Need a new set of shocks on that too, but those shocks are original :).
Steemax
Los Angeles
I guess it’s up to you. If it’s not a primary vehicle maybe you can try for another set through warranty but I’d say $100 a corner is a good compromise.
GATORB8
CLT NC
The options for the Land Cruiser will be quite a bit more limited due to the IFS.
I'd agree the 5100s are similar in ride to the stock Rubicon shocks with the 4xe weight, but may be a little stiffer than the sahara spec.
R3TRO
Pasadena, CA
'20 Jeep Willys
Film Industry
Does the shock failure have anything to do with the extra weight of the 4xe?
alphawolff
california
2021 JLU
thanks!
i've seen wrangler shocks leak as little as 5k miles, it's a bit of a crapshoot on how long they last. id just let the dealer warranty them while its still under basic, then look for upgrades afterwards if you don't plan on lifting it
4xe safari
Tasos
4xe
thanks!
I hope you found a solution under warranty. I had the same issue same car. Installed factory shocks had wrong part number to the car type seemed to be the non phev. Luckily springs had the correct part number. What to say… one more issue from the long queue… Covid cars
