DId you order your jeep with Hard Top? I wonder if the dealer swapped Hard Tops from an earlier jeep onto yours as this issue pertains more to the actual HARD TOP than JEEP itself.Mine was built after 6/27 but still has this issue.
You'd assume that all JL's manufactured after 6/27/18 would have the check valve installed at the factory. TSB says the bulletin is for all JL's manufactured before 6/27/18.So do all newer built Jeeps already have this installed then?
I would have had to go change clothes after finding that, I’ve been in south Texas for about 10 years and finding a snake always gets my attentionAfter doing the check valve install yesterday, I did not add wiper fluid to the washer reservoir. Early this am, I opened the hood to get to the reservoir and this was hanging out of the air canister opening. He/she was 5-6 foot long. See pic taken after I yanked it out of the canister.
