inJeepious
David
Rockville, MD
24 Jeep Wrangler Rubicon X (3.6L)
Something often overlooked — oil undercoating can block your breathers (make sure these are protected, especially your rear diff breather). When that happens, trapped pressure can destroy your diffs or cause leaks.
I’ve relocated all 4 breathers and switched to sintered bronze filters with great results. They allow consistent airflow while blocking dust, moisture, and pressure spikes that can force oil past the seals. In my latest video, I go over flow rates, placement, and why this setup outperforms typical hose extensions.
Would love to hear what others are using for breathers — anyone else running bronze filters or custom setups?
jharp
Justin
Kitsap County WA
2025 JLUR, 2024 JT, 2025 R1S
I've used sintered bronze snubbers and filters for years in industrial process control applications.
They work very well, you just have to get the micron size right for the application - gasses require low micron rating. Thick, heavy oils require a higher one. For keeping water out, I'd shoot for a mid-micron rating (20-25um)
The main thing as you pointed out is reasonable flow rate, and keeping water out. Me, personally, I'd run sintered bronze filters mounted as high as I could get them.
One thing you might notice is a slight gear-oil smell wafting up from under your rig if you run bronze filters, they do not stop the vapors from exiting the breather quite like teflon/gore fabric does...
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
Jeep Wrangler JL Testing the Best Diff Breather — Why I Chose Sintered Bronze Filters for My Jeep 1762884844108-6h
Run AC Delco Grape scented fluid.
Yes that is a real product.
yokramer
Snark Incarnate
Ok, now that's just cool... I might buy a bottle just to sniff it.
Just cause there is also grape in with diff fluid doesnt make it a good scent.
inJeepious
inJeepious
David
Rockville, MD
That’s great insight — I really appreciate you sharing your industrial experience with sintered bronze filters. The micron breakdown is super helpful — I agree, 20–25 µm seems to be the sweet spot for keeping water out while still letting pressure vent freely.
jharp
Justin
Kitsap County WA
You could error on the side of caution and go with 40-50um to be certain water can't flow across the membrane. It will slightly lower gas flow, but not enough to be significant.
inJeepious
inJeepious
David
Rockville, MD
@inJeepious any links to buy filters, hoses, etc?
Sorry for the delay — I still need to get the video out showing how I ran all the lines, the parts I used, and the full setup. Since posting the last video, I actually moved my rear diff hose inside the taillight housing. It’s a shorter run and even more protected there, so it made sense to update it.
Getting the breather off the transfer case is the tricky one — you won’t actually see it, you have to reach in and feel for it. It’s tucked up high, and the angle makes it awkward, but once you know where it is, it’s not too bad. I’ll show the exact technique and hand position in the video so it’s easier to find.
(See pic below — it took me quite a few tries to get the video and then capture a frame that actually shows it.)
In the meantime, here are the exact parts I used (all from Amazon at the time):
Uenede 6-Pack Brass Hose Barb Fittings
1/4” NPT Female → 5/16” Barb, includes stainless clamps
(Used for adapting the diff/TC/trans lines to the sintered vents)
PneumaticPlus BV-28 Sintered Bronze Breather Vents
1/4” NPT, brass body, pack of 10
(These are the vents I replaced the Gore caps with)
Continental 65127 Fuel Hose
5/16” ID, 50 PSI, SAE 30R7, 25 ft roll (plenty if you run the rear diff into taillight otherwise you will need more)
(Used for all the relocated breather runs)
Zip ties
(For clean routing and preventing any U-shaped dips)
Transfer case breather pic:
Jeep Wrangler JL Testing the Best Diff Breather — Why I Chose Sintered Bronze Filters for My Jeep 1763174303813-8a
inJeepious
inJeepious
David
Rockville, MD
Video’s up! I walk through two ways to run the rear-diff breather. Honestly, the taillight route is the way to go — super short, clean, and well protected. The other three breathers are all run up to the engine bay.
If you do choose the long run for the rear diff, definitely step up to 3/8” hose — the length and natural low points can add restriction. Also keep an eye out for any downward dips or U-traps. I break all of this down in detail in my first breather video.
