Zerk fittings
autotragic
the cornbelt
'21 JLR 6MT
Am I the only one that won't buy parts if they have zerk fittings that need to be greased?
Add that to my pet peeves about aftermarket shit. I don't want grease fittings on a vehicle that came with none just like I don't want random SAE hardware on a metric vehicle.
bah humbug
Terrymo
Terry
2023 JLURXR 3.6 ET
Am I the only one that won't buy parts of they have zerk fittings that need to be greased?
bah humbug
I’m with you on both of those. So many first world problems though, I gotta choose my battles.
Terrymo
Terry
2023 JLURXR 3.6 ET
I see this is an old thread that has been revived twice but my favorite mod to any grease gun is a LockNLube coupler. It locks onto the zerk so all the grease goes in vs squirting out from around the zerk.
I like the Lincoln 1134 Pistol Grip Grease Gun. A pistol grip gun is easier to use than one with a long lever. It only needs one hand. I suppose a clogged/stuck zerk or a bushing full of hard dried up grease might need the force of a long lever gun but that is a rare case for me and I have one around for that.
Thanks I’m going to try that coupler, just because.
Terrymo
Terry
2023 JLURXR 3.6 ET
@roaniecowpony @chevymitchell @grimmjeeper @Roky etc. I see aftermarket 1310 and 1350 driveshafts have a flat zerk recessed on the pin. What needle fitting works well. Snapon$$$, Matco$, or? I’m all for buying good tools and dont generally buy Snapon unless I need to but definitely not cheap junk. Thanks
Roky
Roky
To be honest, I don’t even know what brand I have, lol… I just grabbed one at the parts house, it’s not something I have a preference on… they all work…. That said, I probably have a Snapon in the box, only because my buddy has a franchise, lol..
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
I use generic parts store stuff. Some of it breaks early and I go buy another one from a different parts store. Eventually I find one that doesn't break and then I forget where I got it.
Terrymo
Terry
2023 JLURXR 3.6 ET
I was hoping y’all had better memories than I do. 🤓 I think I’m leaning toward Matco unless someone else has some wisdom to impart.
roaniecowpony
Retired Engineer
Recently, I bought a couple Loc-n-Lube grease gun couplings and a rubber tipped accessory from the same company. I tried to use the rubber tipped accessory on my Reid Racing knuckle grease fittings. It was laughable. I dug out an old cheap solid steel needle from the rack at a local parts store that I simply pressed hard against the grease fittings and it seemed to work well enough.
Jeep Wrangler JL Zerk fittings needle grease ti
Terrymo
Terry
2023 JLURXR 3.6 ET
Sounds like a classic case of overthinking on my part
Badunit
VA
1997 TJ, 2023 JT
I use a Lincoln 5803 needle nozzle for the double cardan joint on on my Ram.
