You need this LP Bracket
Vector Offroad
Rock Sponsor (Level 1)
Utah U.S.A.
vectoroffroad.com
2018 Wrangler JLU
Offroad Manufacturing
Made In The USA
If you are replacing your stock factory bumper, you need this bracket to re-locate your license plate.
  • Main Plate laser cut out of Aluminum. Camera Housing cut and bent from stainless steel. Product ships raw.
  • Stainless Steel Custom Machined Extended Lug Nuts for Mounting. Remove 2 spare tire lug nuts, and add our mounting lug nuts for product installation. Simple to install
  • Included ORO Brake Light and License Plate combo light mounts behind the license plate Housing Bracket. One set of quick disconnect ends to allow for easy removal of wiring
  • Bolts Directly to Factory Wheel Lug Pattern. Only works with Factory Wheel Lug pattern on JL or JK
  • Works On JL and JK, but JK would need to run JL style Camera Wiring and Camera
  • Factory Camera wiring works with your own factory JL Camera
  • Some splicing of wires required for quick disconnect brake and license plate light. Quick disconnect wiring terminal ends are needed to allow removal of spare tire.
This Product allows you to relocate your License plate to the spare tire. Perfect for your vehicle if you have removed your Rear Bumper on a JL, or the License plate bracket on your JK. This Kit only works with factory lug pattern wheels. The wheel must be at least 17" to fit this plate. The kit comes with a Camera Housing to mount the JL camera, as well as a brake light, and license plate light combo. Factory license plate wiring needs routed through the tailgate to install the license plate light. Brake light wiring is already routed for this type of install
https://vectoroffroad.com/products/wrangler-license-plate-relocation-kit
Jeep Wrangler JL You need this LP Bracket IMG_3173
Jeep Wrangler JL You need this LP Bracket IMG_3176
74bronco_nomore
Reno
2019 JLUR, 2013 JKU, 2005 Dodge Quad cab, 2005 Audi A4
This looks great! I love how tight it pulls the plate in! But can you confirm it works with OEM Rubican wheels or Method 703 wheels which I'm migrating to soon. Thanks in advance.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
I love my e-dock. But, $145 for a license plate mount, ouch.
Vector Offroad
Vector Offroad
Utah U.S.A.
vectoroffroad.com
2018 Wrangler JLU
Hello, thank you. Yes it will work with those wheels, as long as they are 17” in diameter
Vector Offroad
Vector Offroad
Utah U.S.A.
vectoroffroad.com
2018 Wrangler JLU
If you don’t need the third brake light, it would run $99.99. Made in the USA out of stainless steel machined parts, and aluminum, and laser cut and bent stainless steel. . There are definitely import products that would cost a bit less, but not nearly as nice.
JL_Noob_22
Larry
Eastern, NC
2022 Sahara Unlimited
Am I missing the camera in the pics? Any pics showing the camera installed? Are there printed instructions you can share? (Yes, I watched the video, but it didn't show this)
Vector Offroad
Vector Offroad
Utah U.S.A.
vectoroffroad.com
2018 Wrangler JLU
Hello,
message us [email protected] for more information on the plate and additional images.
Jeep Wrangler JL You need this LP Bracket IMG_4652
