Yet another failed visor question
MitsJeep
South Carolina
2018 Black JLUS
We've got almost 90k miles between 2 JLs and with the wife commute (east in the am west in the evening) the visits get used every day. Have we just been lucky or are you guys doing pull-ups on your visors?
Im in the same boat. Ive never had this issue, and I cant figure out what exactly everyone is doing to break these lol. 66k on mine.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
It's not necessarily the pulling of the sun visor down to the downward position that causes the damage....
IF all you do is move the visor to downward position and then move it back up (even forcefully) then you will not break it.
It's when you detach the visor from the end holder, extend the visor and say swing it a tad roughly, in front of the door window. The lever effect of the extended visor changes the dynamic and the visor bracket will break/pull free.
Some owner's, do not even realize the visor can be detached fro them end holder, extended and swung in front of side window in order to prevent sun coming in from the side window side.
MitsJeep
South Carolina
2018 Black JLUS
It's not necessarily the pulling of the sun visor down to the downward position that causes the damage.... IF all you do is move the visor to downward position and then move it back up then you will not break it.
It's when you detach the visor from the end holder, extend the visor and swing it in front of the door window. The lever effect of the extended visor changes the dynamic and the visor bracket will break/pull free.
So owner's do not even realize the visor can be detached form end holder, extended and swung in front of side window in order to prevent sun coming in from the side window side.
Wow! Ok, now that makes sense. I knew they could be detached, but I rarely disconnect my visor at all. I think I have maybe only done it once or twice.
It will stay connected as much as possible, ha.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Some of us do know how a visor functions and use that feature all the time with 0 failures in 90k miles, I still think people are pulling down as they swing the visor out or something? Maybe they use those visor mounting accessories and have extra weight on their visors? Just seems weird that some think it's a design flaw and a rocking time bomb and yet countless others have years of trouble free operation, something doesn't add up.
Rhinebeck01
Retired at 55 ..
Reality is some people are more deliberate/careful when they do things..
I know, I myself am.... and I encourage my passenger to "go easy" when dealing with the visor when it is not secured in the end holder...
Even then.... I installed a set of Taccom singles.. I like added insurance... I travel many miles monthly/yearly and use visors alot...
Less then $5.00! Cheap and effective insurance... Takes about 5 min to do the easy install...
https://www.amazon.com/TACCOM-compatible-Gladiator-Wrangler-PENDING/dp/B09LDF4DT9/ref=sr_1_1?crid=108VEK56392I4&keywords=taccom&qid=1697633442&sprefix=taccom,aps,86&sr=8-1
Terrymo
Terry
2023 JLURXR 3.6 ET
Reality is some people are more deliberate/careful when they do things.. I know I myself am and I encourage my passenger to "go easy" when dealing with the visor when it is not secured in the end holder...
Less then $5.00!
I considered them to be cheap insurance and they only take a few minutes to install. Apparently they are far cheaper than when I bought them.
ninab64
ninab64
Nina
St Johns, FL
2025 Jeep Wrangler Sahara
retired
You've been quite lucky, I would say. I am not hard on visors, and only sometimes have a passenger in the front. Why the passenger's visor would fail the same as the driver's can only be due to bad design, imo. Better to be safe than sorry, because both times I had them fix it under warranty it took a long time for the replacement parts to arrive. Then, time in the shop for the repairs.
ninab64
ninab64
Nina
St Johns, FL
retired
I think I paid $19 for the pair at the time.
Terrymo
Terry
2023 JLURXR 3.6 ET
That sounds about right. I wonder if they changed from aluminum to Delrin or something similar to reduce the cost.
Joe98
Sydney
2019, 2 door Sport S, Mojito!
I am over 60yo. I have never heard of any car of mine, or my friends, or my dads or his friends, where the sun visor falls out. None!
I move the sun visor as I have always done. Just flip it down.
Before I repaired it, I could see a broken plastic collar. If the collar was metal, It would have cost 5c more and us jeep guys would have one less thing to complain about.
