Wiring Portable ARB compressor to Aux button??
kah.mun.rah
Merenkahre Jr.
Duat
I am converting my portable ARB Twin compressor to an on-board air system and am looking for some advice on wiring it into the factory Aux buttons.
The plug for the on/off switch coming out of the ARB Twin compressor has a black, red, and purple wire. The problem is that every ARB Twin wiring diagram I find only has the black and purple wire on them.
My guess is that the black goes to ground and the purple goes to the Aux button wire.
The question is, what do I do with the red wire?
a) cut it, not needed
b) combine it with the purple wire to tie into an aux wire
c) run the purple to an aux wire and the red to the ignition wire
d) other
Thoughts @Tncdrew, @Tech Tim, @Northridge4x4, @ARB4X4, @Terrymo, @Yawnie'sPapa, @sourdough, or others?
Switch wires coming out of compressor:
Jeep Wrangler JL Wiring Portable ARB compressor to Aux button?? 1685993597005
Aux wires under dash (borrowed from another threa):
Jeep Wrangler JL Wiring Portable ARB compressor to Aux button?? 1685993645193
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
Hate to say it, but use the Search - already covered
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
I'd have to dig into it more... my ARB Single compressor's wiring is a bit different.
Others can chime in.
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
This is a great install video- for the single, but the wiring should be the same.
The actual wiring instal starts at 18 minutes. I did mine this way two years ago and still works without issue.
The main power and ground wires are on a seperate line. Only one wire (red) was needed from the 'switch' bundle of wires. It is what gets connected to the aux wire.
Terrymo
Terry
2023 JLURXR 3.6 ET
Sorry I didn’t use the aux switches, just used the arb switch similar to this but mounted under the passenger seat….Grimm Off-road pics
Jeep Wrangler JL Wiring Portable ARB compressor to Aux button?? IMG_1579
Jeep Wrangler JL Wiring Portable ARB compressor to Aux button?? IMG_1576
Jeep Wrangler JL Wiring Portable ARB compressor to Aux button?? IMG_1577
Jeep Wrangler JL Wiring Portable ARB compressor to Aux button?? IMG_1578
Speed331
Sean
Las Vegas, NV
I think you only need the red. The black and purple are prob for illumination on a seperate switch.
This is strictly without seeing a diagram, but that is how the wiring for the single worked. You only need a power line to trip the relay...
kah.mun.rah
kah.mun.rah
Merenkahre Jr.
Duat
I have spent hours and hours searching and I can't find any info. here on the Forum or online about how to tie the "red" ARB switch wire to the Aux wires. Everything only talks about the black and purple wires.
kah.mun.rah
kah.mun.rah
Merenkahre Jr.
Duat
Thanks. Yes, that is similar to how these three wires are tied to the switch on the original portable compressor setup. I just don't know how these correlate to the Aux wires under the dash.
Jeep Wrangler JL Wiring Portable ARB compressor to Aux button?? 1685998840093
kah.mun.rah
kah.mun.rah
Merenkahre Jr.
Duat
This is what the ARB diagram looks like. The plug labeled "2" is where I have the red, black, and purple coming out and the diagram only has black and purple shown:
Jeep Wrangler JL Wiring Portable ARB compressor to Aux button?? 1685999036310
Jeepeto
Josh
North Texas
2021 JLUR XR
Sparky
I have spent hours and hours searching and I can't find any info. about the red ARB switch wire here on the Forum or online.
Apply 12v to the purple. That’s all you need. I did the same with my rig, completely stripped the wiring harness and only used the purple wire.
Edit to add photos:
Confirming, as it’s been a couple years. The purple is all you need, this is my aux taps in the passenger footwell.
Purple is the compressor tied into my aux tap for switch #3
Red is my radar detector tied in with the ignition switched tap included in the aux bundle.
Jeep Wrangler JL Wiring Portable ARB compressor to Aux button?? IMG_5240
kah.mun.rah
kah.mun.rah
Merenkahre Jr.
Duat
Thanks!
Speed331
Sean
Las Vegas, NV
Jeep Wrangler JL Wiring Portable ARB compressor to Aux button?? ARB Dual Compressor Wiring Schematic
Matches what you have.
If purple (from Jeepeto's post) works then great...
....but annoying from ARB, in automotive systems 'red' is power and 'purple or blue' are usually for illumination purposes.
Speed331
Sean
Las Vegas, NV
Thanks! Based on that diagram, would you tie the blue or the red into the Aux wire?
Red for power.
Blue or purple is usually for illumination in automotive wireing.
Speed331
Sean
Las Vegas, NV
You know what. After a closer look at the switch they set up. The red is supplying power into the switch and the blue is bringing it back to the compressor.
So in this case blue - or purple- should be connected to Aux.
Should have looked at it closer. Sorry.
