Windshield Header Seal replacement
GregorioJL
Greg
Germantown, MD
2018 Jeep Wrangler JL
In case anyone else has a trashed seal. These seem to have a small lifespan.
There aren't any instructions, but installation is easy. Almost no adhesive is required. The kit includes both the inner and outer seal as an assembly, and each mount on a vertical metal flange. The only adhesive required is a small dab on the end corners. The new unit has small felt strips on the corners that aren't on the original 2018, probably to prevent snags.
Each end has three fasteners. The top fastener is a reusable plastic that can be removed with a panel tool. The bottom two fasteners are black metal rivets, if you want to repro that. I used small black cable ties.
Mopar 68271695AG
Jeep Wrangler JL Windshield Header Seal replacement Windshield Header Seal 1
Good for another few years:
Jeep Wrangler JL Windshield Header Seal replacement Windshield Header Seal 2
Jeep Wrangler JL Windshield Header Seal replacement Windshield Header Seal 3
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
What actually happened that it needed to be replaced ?
df007
2019 JLU Sahara 2.0
Mopar 68271695AG
Thanks for the info. Did the seal kit come with new rivets and hardware or would those need to be ordered separately?
Also, I know on the JK the seal has a glue strip on the front where it butted to the windshield frame. Is this also the case with the JL?
