Will this wheel tire setup work on a XR?
MVOffroad
2021 Jeep Wrangler Rubicon
So after much deliberation I've landed on the Kenda Klever RTs 37x12.5R17 and the teraflex nomad deluxe 17x8.5 with 4.75" backspacing. I have the XR Rubicon. Is this an appropriate setup?
Caliguy
Norcal
2022 Rubicon JLU
It should work no problem. The 8.5” wide wheel on a 12” wide tire should be ok. Backspacing and tire size I think doesn’t rub in most situations (maybe rear fender)
MVOffroad
MVOffroad
Would it be better to have wider than 8.5"?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Meh, some trade offs either way. There are some minimal effects on section width, but you're also getting the wheel face closer to the sidewall, so it's a little more exposed to rock rash.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Many here are having zero issues with 12.5" wide tires on the factory 7.5" wide wheels. I have 13.5's on 9" wide wheels and zero issues. A wider than necessary wheel will only add extra weight to the wheel and tire assembly. You'll be fine with the 8.5's.
JT1
Broken Arrow, OK
2021 Willys Gladiator
maybe others can chime in but I think a 10” wheel is more optimal for a 12.5 tire
If you air down and don't use a beadlock wheel, a wider wheel will lose a bead easier. IF you are low speed in sand or soft dirt, no issue. But if you run soft sand at speed or rocks, I would stick with a 9" or narrower wheel.
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
I agree. A 10" wide wheel is more optimal for a 12.5" wide tire. I had 37x12.50R-17 Cooper STT Pro tires mounted on the OEM wheels that came on my 392 XR. The OEM XR wheels are actually 17x8 when used in the non-beadlock position, and 17x 8.5 if used in the beadlock position. 17x8 wheels will work on a 12.5" wide tire, but it is not optimal width. I changed to 17x10 wheels, and the tires fit the wheels much better.
Caliguy
Norcal
2022 Rubicon JLU
I’m not sure a wider wheel will lose a bead easier. If you think about it, a narrower wheel has to stretch the tire further to hold its bead which would mean it’s under more tension than the wider wheel and vm the added tension pulls or pushes it off the bead.
I guess the counter argument would be that the added tension holds it onto the bead tighter and less likely to let go. Hmmm
JT1
Broken Arrow, OK
Some of it depends on how far you air down too.. at 20psi, none of it matters. At 9, I'd want the narrow wheel.
