Will it Rub
Ilir
Ilir
Chicago
2021 jeep wrangler unlimited Willys
I am looking to get a set if this wheels on my stock 2021 Willys to go with my 285/75 Ko2s will it rub or it going to be fine? The wheels are going to be 17X9 -12!!
Jeep Wrangler JL Will it Rub IMG_0267
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
34s on stock willys with low fenders and -12 offset wheels - you will rub your fenders at full flex to one side with sway bar disconnected. Without swaybar disconnect its a may-be rubs
rossneill
Ross
Baton Rouge
Jeep Gladiator 2023 sport
It depends do you have a steel bumper and winch you will have tire poke I went with +12 to have less poke and add a fender flare I also put 265/70/17 I didn’t want to lose mpg are you reusing your tmps sensors if you buy new ones make sure you get the right one they are self learning I used pepboys and they mounted and balanced installed valve stems for a hundred dollars I did have to buy new lugs nuts but I now have a spare set of tires and I didn’t need to do the spare I did install the tires myself on the jeep if it dose rub a spring spacers should take care of it
Ilir
Ilir
Ilir
Chicago
This what i have for winch and bumper set up, and i will eventually do a 2.5 AEV lift on it before the end of the year!
Jeep Wrangler JL Will it Rub IMG_0011
vadim4o
Vadim
Bayonne, NJ
2020 Willys EcoDiesel
I have 285/75 Ko2s on stock rims with 1.75" spacers (stock bumpers, no winch), 2020 Willys Ecodisel.
Per https://tiresize.com/wheel-offset-calculator/ yours are going to be 0.45" further away from frame/suspension, everything else the same.
I had rear tire rubbing *without* swaybar disconnected... changing fender flares soon.
Jeep Wrangler JL Will it Rub PXL_20241115_193109749
