Why would they do this? Every reservoir clear except coolant.
JABCAT
Prosper, TX
'20 GC High Altitude 4x4, '22 JLU on order
College Professor
Just pop the cap and look down into the hot radiator like a man!
Agree with simply removing the cap & checking levels. Iirc the fluid reservoirs on my other vehicles are either black or opaque.
Megawatt
Sin City aka Vegas
money pits: Turbo Busa, Street Bob, 22JLUR snazz, 5.0 mustang MT
Powerplant operator
Damm. Some people just want to be spoon fed. I got the meaning of the thread just fine. Nice vid.
m3reno
Sal
caldwell
2022 Jeep Wrangler JLU
I used to own a turbo charged Porsche which had a pump connected to the coolant that fed into the turbo. It stayed on for a few minutes after shut down. That helped the turbo charger from developing coking. Do you guys with the 2.0 turbo have that set up?
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
Yes. My Eurovan has a pump like that and it's not even a turbo.
jjvincent
Bethlehem, PA
Mechanical Engineer
In addition to the dipstick, if you stand on the front bumper, take the cap off, use a flashlight, you'll see a yellow tab down in it that has max and min on it.
As someone mentioned, it's black because it's so close to the turbo. Thus a different plastic to keep it from failing too early.
Plus, if you ever owned a BMW (i.e. every e46) the container is black (even on an M3). New BMWs are the same.
Pinky Tuscadero
Kenosha Wi
2021 Pink RHD Wrangler 2015 RHD Wrangler
All the other reservoirs are white so they needed a black one for political correctness
Affirmative action, MLKJ, George Floyd, Kenosha riots.... Jeep gets it at last ?
Can't we all just get along ?
Heimkehr
Pennsylvania
2021 JLU 2.0T
My wife's CR-V has a 1.5T. A fun little engine. Anyway, the pressured coolant reservoir is ostensibly opaque, so as to accommodate visual inspection. I still can't discern the coolant level without holding a flashlight directly on top of the tank itself. This is likely due to the thickness of the polymer construction required to allow safe pressurization.
The overflow tank on my daughter's [older] CR-V isn't pressurized, and is thin enough to easily observe the level of blue coolant sitting therein.
LuvHydro
LuvHydro
Midwest
21 JLUS Hella , 22 JLUSS Hydro
OMG, thank you for injecting some humor.
I got my answer and a laugh.
AZJeepGuy
Ron
Arizona
2022 JLUR Hydro Blue
How often are you guys having to add coolant? And isn't there a sebsor?
Heimkehr
Pennsylvania
2021 JLU 2.0T
How often are you guys having to add coolant? And isn't there a sensor?
I've had to add ~6 oz., once, and only after I checked the reservoir in response to this thread.
As for sensors, I've an analog temperature gauge, with a redundant digital display of the same data on the central TFT screen. If I'm not paying attention to either one, that's my fault.
four low
central New York
2018 JL
The 2.0T black radiator coolant reservoir has a yellow cap with a dipstick. Unscrew it and Behold ! The coolant level reveals itself.
Thanks for the info on why it is black plastic for high heat resistance.
LuvHydro
LuvHydro
Midwest
So it's, unscrew cap, pull out the dipstick, wipe it off, insert and check it again, screw it back on then dispose of the paper towel.
As opposed to glancing at it while I scan the others.
