Wheels
Ashley
Palm Springs, CA
2018 wrangler JL unlimited sport
Hello, I am looking to upgrade my wheels and tires. I would like my tires to stick out about an inch maybe a little less. What offset would that be? Someone please explain that to me!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Visualizer: https://tiresize.com/wheel-offset-calculator/
Your stock wheels are +44.5 mm offset. Stock tire size is on the door sticker or on the side of the tire.
Lower offset moved the centerline of the wheel/tire assembly outward. 25.4 mm is an inch, so +19mm offset is about an inch further out.
You also need to add for half of the tire width increase. Using metric tire measurements the width is the first number (also in mm). Every inch of width adds half an inch of "poke".
That link will calculate all this for you.
Blues Fan 30
St. Louis
Mine are kmc 550 which are 17x8.5 and have a +10 offset. Imo perfect amount of poke and right around what you're after.
Jeep Wrangler JL Wheels 20240129_104257
Remorseless
NC
-35mm offset looks about right
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
If you want them to stick out an inch or less, then zero offset. Look at the picture @Blues Fan 30 posted above. His are +10, if you go with zero, they will stick out another 1/3" or so.
Don't go into the negative offsets on a stock suspension, it looks off and may rub on the fenders when you turn.
As a basic rule, the more lift, the bigger the tire, the more offset you can go.
Pig-Pen
Banned Camp
2018 JLU
jabroni
it matter which model you have. does it have the wide or narrow axles? a set of wheels that stick out on a sport are really going to stick out on a rubicon.
Slate
Kentucky
'̶9̶̶7̶̶ ̶W̶̶r̶̶a̶̶n̶̶g̶̶l̶̶e̶̶r̶̶ ̶S̶̶p̶̶o̶̶r̶̶t̶̶, '21 Willy's, '23 Rubi 4XE
Aussicon
Cape Cod via Australia & N.Z
2021 JL Rubicon Unlimited
This is a Rubicon with Method 703s in 17x9 -12 Offset (4.8 backspace)
Jeep Wrangler JL Wheels IMG_1787
Al G
AZ
2020 Wrangler JLU
That looks perfect. What size are your tires?
Blues Fan 30
St. Louis
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
gek
Code Monkey
I have learned ALOT on this forum, but not from using search....
The forum can teach you A LOT, even more if you search. It is not great with spelling though. Alot isn't a word.
Jeep Wrangler JL Wheels typol-spelling-police
