What size winch for JLR 2dr?
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
If the 9,000 lbs Super Duty isn't going to require 9000 lbs. of force applied to move unless it's REALLY stuck, then why get the biggest winch you can afford and will physically fit? Are you/we buying for a circumstance that isn't going to happen, and are there better ways to mitigate that risk (like learning good winching techniques)?
STW
Utah
2022 JLR 2door 2.0T Rubicon stingrey
Back when people considered winches big money, 5000 was sufficient.
I use an 8k, never needed more.
+1
8k has always been plenty for me too (TJ). But when setting up a new JLR, I couldn't use my preferred 8k winch, and the 10s didn't seem different in size from the 8k versions, so why not have the extra capacity if it fits and works.
STW
Utah
Personally I'm running an ancient Warn HSI 9500 on my JLR, an 8,000 lb Warn M8274 on my big dog CJ-7 and a Warn M6000 on my Samurai (which has pulled a diesel K5 Blazer out of the mud).
What do you notice about line speed difference between your 8274 and your 9500?
My TJ has 8k 8274, which is known for good line speed, and I'm going to a Warn 10s so curious how slow the line will be compared to 8274.
STW
Utah
I guess I don't know. Does it matter where the motor/winch is located, or will the lighter vehicle always be pulled to the heavier vehicle (conditions being equal)? Is the fixed object (heavier vehicle) really pulling the lighter vehicle (Jeep with winch)?
The hope is that the vehicle in neutral (or driving) will be pulled toward the vehicle with brakes on.
dragoneggs
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Just pushed the buy button for a Zeon 8s. It will arrive a month before my JLR I'm guessing. Just making the wait more agonizing. :)
Kreepin1
Kirk
Central Illinois
1982 CJ7, 2006 TJ, 2012 JKR, 2021 JLR
No surprises. The 8274 is scary fast when spooling the line back in. The HS9500i is a bit faster under load. I enjoy using both winches. Assuming you mean the Zeon 10s Platinum (and not the EVO junk) you'll be happy.
