What is this???
TopGunViper
MO
2021 Jeep Wrangler Rubicon Unlimited
What is this behind my window switches?
It’s not plugged into anything…
Jeep Wrangler JL What is this??? IMG_8924
Jeep Wrangler JL What is this??? IMG_8925
"D"
Denver
Southern Tennessee
2003 Dodge Dakota 4x4. 2020 Wrangler JL 2Door
Most car companies use only one wiring harness. All cars come with the same harness which covers all of the options offered by the company. Just think about the cost to make a harness for each model. To answer you question, this is a 10-place Molex ( I think)connector female plug. What is it for? Probably some option your vehicle does not have. Hope I haven't bored you or sounded like a "know it all".
TopGunViper
TopGunViper
MO
Thanks for that info!
I just had the factory aux switches installed and i don’t think the switches are working. The lights aren’t lighting up when I click them.
I have the TazorJL and have programmed the Jeep for the aux switches and I can see the aux switch in the settings now.
the dealer said it’s in my settings but it’s not showing up on the jeeps computer so I will have to take back and have them flash the computer.
I thought maybe something wasn’t plugged in which they’re not working.
Tazor said they will work by programming it but maybe not…?
Deleted User 38384
What year is your Wrangler?
I have a 2021 Willys sport EcoDiesel with the tow package and auxiliary switches, I do not have that plug behind my dash.
Maybe it's something new on 2024s?
TopGunViper
TopGunViper
MO
2021 wrangler
TopGunViper
TopGunViper
MO
The connector looks identical to the plugin they just installed for the aux switches.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
What color are the wires? Should be easy enough to check wiring diagrams for the match.
TopGunViper
TopGunViper
MO
I’m just going to unmarry the TazorJL and take Jeep back to the dealer and let them flash the computer. Hopefully that’s what will fix it.
mwilk012
Service
Do you have the options for the aux switches on your Uconnect settings menu?
TopGunViper
TopGunViper
MO
Yes, the aux switches show up in the settings and you can click into the 4 switches and change settings but the switch itself isn’t working.
I read where in the past, this would happen and a Tazor update fixed this. Wonder if something in the software broke again.
lashlee
Knoxville, TN
'18 JLUR 2.0 Turbo 4 (Sold), Tesla M3P
I would make sure that the orange wire in the kick panel is connected. I installed one for my best friend and didn't get the connector snapped together completely and it was identical to the situation you're in. I pulled the kick panel apart and snapped it together and every switch started working.
TopGunViper
TopGunViper
MO
Yup, the issue was the dealer didn’t install wiring correctly.
They fixed the wiring flashed the computer and my aux switches lit up when pushed and power going to my lights hooked up to aux switch.
I was getting in the car to leave and seen they left the OBD2 device on the Jeep so I let them know. They pulled it out and I left the dealership.
as I’m driving home, notice I have a check engine light on and my radio setup looks way different than before. I went into settings and missing a lot of the settings that were there before and missing the aux switches also. My lights hooked up to the aux switch isn’t working.
Ugh!
Will have to go back to the dealer tomorrow again!
TopGunViper
TopGunViper
MO
Update:
Guess it needed some ignition cycles as all settings are back, check engine light is off, and aux settings are back in settings and working.
Phew!
mchastings
Calvin
San Diego
2013 Sport S 2Dr / 2015 Rubicon JKU/2020 Willys JLU Diesel
Working to pay my Taxes
Once a twigit, always a twigit! Signed ENCM :)
Jocko
Boston
Earl 4xe Rubicon
Haha you'd think so, right? Makes perfect sense and I wish you were right! I had to replace a front door wiring harness recently. Believe it or not there are 5 different wiring harness part #s for the drivers front door and 5 others for the front passenger door each covering various combinations of door options. You have to put in your VIN to determine which is right for your Jeep. 🤷‍♂️
