What is this.
mhdjeepjl
UK
Jeep Wrangler JL 80th
How do you "reflash" the cluster? My rearview camera has guidelines on Mondays and Wednesdays sometimes, and then at random times, no lines at all!
Valpo Jeep
Doug
Valparaiso IN
I have seen the 999,999 miles too many times to count but it will correct itself in less than a mile.
A couple times it has told me the outside temp was 800*F
Many times it will not show ANY mileage at all.
A few times it told me to push the clutch in on my automatic to start the rig.
Supposedly you can go to the Jeep dealer and get the latest software software flash done to correct this. But it will cost you an hour of shop time for a useless fix as the errors do not impact drivability.
Did this before and after new batteries.
S2k Chris
Arlington Heights, IL
AP1 S2000, Willy’s, Honda CB360 project
Food industry finance
I’ve not had a Jeep (or any car with software flashes) out of warranty so pardon the possibly silly question: if you were to schedule, say, an oil change or other service and ask them to flash it to the latest software version at the same time, is that something you’d get charged for? Or is that generally a free service assuming you’re already paying for other shop time?
MitsJeep
South Carolina
2018 Black JLUS
I Know that you have to pay whats called the "diag fee" as it was explained to me. I was having the recall fixed for the steering stabilizer and the can cbus thing fixed so- All I had to pay was for the $200 diag fee.
To me, it was far worth it as I paid for this vehicle and want stuff fixed that can be. I know others may have differing opinions, but my take is I want stuff fixed and kept.
Outside of that- it has not been to the dealer and I do not intend to take it there for anything else.
Maverick909
I.E.
Your batteries aren't just on their last leg, They're on borrowed time!
Thank them for their exceptionally long service and put them out to pasture.
If you don't have eTorque, replace both Main & Aux.
LOL, MY 18 is still running factory batteries and still testing good. LOL Ive had the gensis dual battery kit for 4 months waiting for the batteries to quit and yet they keep on living LOL
Valpo Jeep
Doug
Valparaiso IN
I suspect they would stick you with an hour of shop time even though it will likely take 15 minutes to perform on top of the oil change. I doubt you are getting a certified tech to perform an oil change as well. If the hourly wage of a tech is $20 then his/her total package is more likely $40 per hour which would be most of the cost of an oil change along with shop cost of filter and oil. I suspect you get an apprentice or an oil tech for the routine work. Very little ASE certified knowledge is needed for a simple oil change
Reinen
2021 Jeep Wrangler JL Rubicon
Ah, that vicious corollary to Murphy's Law.
Anything you want to go wrong, won't. ?
Maverick909
I.E.
be prepared for the failure. LOL, my Ram 1500 battery lasted 8 years from the factory as a Daily driver. Hope this one doesnt last that long though
speedymart
mephis
2021 jl
Known issue. You need a new cluster, see a dealer. There a bug in the firmware where it'd get stuck at 13k or so. Even after the fix it still happens, once it shows 999999 it needs to be replaced.
Nitehawk92
Vandalia, Ohio
23 JLU Reign Rubicon 14 Mazda, 22 Hyundia Santa Fe
Retired Air Force Current Civil Service Civilian.
So this happened to me today. I think this battery's is on its last leg. I have a tazer so start/stop has been off for a while now plus battery's is original 2018. Yikes I know.
Man I have never seen a vehicle that had 1 miles short of 1,000,000 miles on it...
Bluandwht86
2018 JLUR, 2020 JLR
Just had my cluster replaced for this issue as well. Had been doing it for a few years but it would always go back to the correct mileage after a few minutes.
txj2go
DFW
The first order of business would be to disconnect the small battery, especially if you are not using the ESS anymore, and see if that helps. If that doesn't help then I would replace the main battery.
I have not seen any of those issues with my 2018. Its original battery was replaced after one year and I've read about a lot of people who have replaced their original battery within the first few years. I realize YMMV but if you need your vehicle to be reliable you probably deserve a new battery.
Bluandwht86
2018 JLUR, 2020 JLR
I have deleted the aux battery and replaced the main battery 2 years ago, and the cluster did the 999999 before and after the batteries were changed.
