What Grease Are You Using?
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
What kind of grease are you guys using on your Jeeps?
I have new tie rod and drag link ends that need "topped off" and would like to know if any of you can recommend what to use. I am in San Antonio Texas for reference.
kapk22
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
I would refer to what the manufacturer of the component recommends.
copy that, will reach out to them.
I've used marine grease in the past while I was in Oregon. Different rig, area, and components now. Thank you for the reply.
zakaron
Pittsburgh, PA
2021 Willys 4dr, 2004 Pontiac GTO, 1986 Honda Nighthawk S
I assume these are aftermarket pieces as I don't recall any zirc fittings on the OEM components. Anyway, years ago I bought the Lucas red 'n' tacky grease to repack CV joints, driveshaft splines and general zirc fitting for ball joints and tie rod ends. I have no complaints with it - and back when I did research on it that seemed to come up with top reviews. It was also readily available at the parts store so I didn't have to special order it.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
I use Lucas Red’n’Tacky or Mystic JT6.
Now I just need to find a grease gun that doesn’t leak when it’s warm to hot outside.
Dusty Dude
Colorado Springs, CO
I also need a grease gun. Any recommendations?
The Last Cowboy
San Antonio, TX
That looks exactly like my Husky, except mine is red. Leaks out of multiple locations.
The Last Cowboy
San Antonio, TX
Old Jeeper
Don
US Army Infantry, IT Engineer
If you are a hardcore wheeler, who sees a lot of terrain, including lots of water, this is about as good as it get. Been using it for over 25 years..
Jeep Wrangler JL What Grease Are You Using? th
https://shop.advanceautoparts.com/p/green-grease-synthetic-waterproof-high-temperature-grease-101/7070077-p?product_channel=local&store=9324&adtype=&product_channel=Local&store_code=9324&&&&&msclkid=4190142ce07a1d16c7e471da1bee20a9&utm_source=bing&utm_medium=cpc&utm_campaign=b_shopping_all_grease/gear_gen_gen_gen_evergreen_eng_aap_us_all&utm_term=4580153136275695&utm_content=Bing_All_Grease & Gear_Grease&gclid=4190142ce07a1d16c7e471da1bee20a9&gclsrc=3p.ds
J.Ferreira
Castle Rock, Colorado
www.tmgps.org
1999 Jeep XJ
There are no zerk fittings on the stock components of a JL, correct.
kapk22
kapk22
Kasey
San Antonio Texas
1990 YJ, 2021 JLUR
CavFab tie rod and drag link, Metalcloak baller joints.
