What gives?!?!??!
jaysmooth24
Juan
Virginia
2021 Jeep JL
After taken my jeep to the dealership for an oil change and tire rotation, I immediately noticed at about 60-65 mph I was getting some shaking in the steering wheel when I never had any previously. Took it to a shop that balanced the tires for me but I am still noticing it. What else should I be looking for?
macintux
Indianapolis, IN
2005 LJR, 2022 JLR
I don’t have any guesses (other than a bad balance) but others might want to know: what lift, what size tires, any other aftermarket suspension modifications, how many miles.
jaysmooth24
jaysmooth24
Juan
Virginia
2021 Jeep JL
Dynatrac Endurosport 2", 35" Toyo Open Country ATIII, Fox shocks, FOX ATS 2.0 Stabilizer, JKS Adjustable trac bar, Teraflex adjustable control arms. Just over 13K miles.
Roky
Roky
Since you noticed it after rotation, try putting front tires on the rear, rear in the front, see if the shake moves to the seat, this will confirm or rule out the tires as the problem.
OllieChristopher
Southern CA
2005 GMC 2WD Sierra, 4.3, NV3500, 3:73/TruTrac
I'm willing to bet they did not use a torque wrench on the lug nuts. All kinds of weirdness happens when the lugs are over torqued.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Any idea how they rotated the tires? Moving front to rear, rear to front, which is typical, you likely have choppy tires on the rear now causing vibration in the front.
But of course, on this forum, it must be someone else’s fault.
Xcoaste
Ben
PA
2021 JLUR - Past - '13 JKU, '97 TJ, '93 YJ
Likely due to your tire rotation. How many miles between your last tire rotation? The more you drive the more it will correct itself as the tires wear, if from the rotation. If the tires have an uneven wear to them, have your alignment checked.
