What does this tell me?
Wbino
NJ
I was playing around with the radio and this showed up in the GPS section.
Jeep Wrangler JL What does this tell me? 088BED84-748A-48A3-BD68-D6AB338EE01B
Jeep Wrangler JL What does this tell me? 7187AB69-95FF-4F27-9DA8-A77867207754
Rscx4
Tampa, FL
21 JLUR 392
Looks like signal strength to the satellites with a confidence level of pinpointing your location. Never seen that, awesome.
Reinen
2021 Jeep Wrangler JL Rubicon
GPS can't track you, signals are incoming only.
This tells you how many GPS satellite signals you're receiving. You need at least 3 to determine your location. The more signals from different GPS satellites you're receiving, the more accurate your position will be.
The dots show the relative position of the satellites in the sky. The more spread out they are across the horizon, the more accurate your position will be. If you're in a canyon and you're only receiving signals from satellites in a small clump, your position won't be as accurate.
So bottom line is it tells you how accurate you can expect the GPS location to be. With 9 satellites spread all across the horizon, your GPS's position fix will be about as accurate as it can get.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
True, but that data is actually fed through the 4G aircard for the OEM navigation to work, so Jeep is totally tracking you.
It could be worse. This is an "option" on 703 of 2022's build sheets:
Remote Monitoring System-China​
Jeepsmashin
Corona ca
Then how did XM guardian tell me my jeeps exact location anytime I used the app and looked it up?
multicam
Tanner
Alaska
2018 4Runner, 2019 JLR
That’s a different system (4G). The post you’re referencing was only commenting on GPS.
For example I have a Garmin Fortrex 401 that I’ve had since 2013. It gives me my location based on GPS signal but doesn’t transmit anything back to anyone. The Jeeps with the 8.4” radio DO transmit back, but not to GPS satellites and not specifically because they have GPS.
2nd 392
Ca
S
Standard equipment on next generation JM. Well.... thought that would be funny....Nope, for some reason!?
2nd 392
Ca
BTW— There Here! Trucking companies have been installing 2 way “Big Brother” dash cams for years that listen as well as watch!!! One of my reasons for early retirement!:swear:
aldo98229
Aldo
Bellingham, WA
Market Research
It is telling you that you are at 82 feet of elevation.
BDinTX
Dallas, Tx
Any idea why 3 of them are blue?
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
If the system is compatible with QZSS or GLONASS that could be the difference, but I haven't looked for much info on Uconnect so I'm shooting from the hip here lol.
Wbino
Wbino
NJ
