Well, that *almost* sucked !
FloridaLarry
Larry
Boca Raton, FL
Rubi 4xe
IT Manager
Dear Jeep:
T H E - K E Y - F O B - I S - T O O - E F F I N G - B I G !!
What, are you guys high?
-Dismayed Owner
Deleted member 59498
Guest
Well you could use the fob for self defense, either as a bludgeon or switch blade the 1/8 inch thick key out for stabbing device.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
@LuvYella
For about $1.25- $1.65, there is, an equally good alternative, it was mentioned earlier....
Many here have used this alternative....
Anyway, just take a piece of foam pipe insulation, cut it the proper length and squeeze it into the space between the front seat (drivers side and passenger side) and the center console.
I used black, pipe insulation that has an outside diameter of 1.5 inches. I used an 11 inch long piece alongside side of both drivers seat and passenger seat.
Do this and no more dropping, charge cards, change, keys or whatver and having them drop down to no man's land so to speak.
You drop something and there it will be sitting on top of that foam pipe insulation, waiting for you to retrieve it,
Yes, the seat(s) will move freely just as they always did.... has no negative impact on the JL. You don't even know it's there til you drop something.
Public Service message: IF you ever drop a credit card, driver's license, etc. in the gaps around the parking brake handle, do not try to pop the cover that surrounds the lever. You will do very costly damage doing this. Better to easily loosen the console and retrieve the item without doing costly damage. Come to the forum and ask how to loosen...
Jeepmarkjl
Chicago
2021 Wrangler JLU Rubicon
Marketing
Yeah someone had a DYI around here I think it was tubing I forget, he was wanting to block the "BlackHole" next to seat.
That was me from several years ago. Costs $1. Home Depot or Lowes. Simple pipe insulation foam. Cut to length. Stuffed in the gap. Stays put. Color matches almost exactly to the trim color. It’s saved so many things from falling into the void.
Guest
That was it the pipe insulation!
MojitoJLUR
Detroit, MI
2018 JLUR Mojito
This actually happened to me in a parking garage. I had to unbolt the passenger seat to tilt it back far enough that I could access under the center console. Sucked big time.
LuvHydro
LuvHydro
Midwest
21 JLUS Hella , 22 JLUSS Hydro
Yeah, filling in that space later today. ?
Jeepney Johnny
Rico!
2020 Jeep Wrangler Sahara
Just out of curiousity...if I dropped a french fry in the gateway to the netherworld...if I find it, like 30 minutes later, it's okay to eat it, right?
VKSheridan
Vince
Broken Arrow, OK
2020 2 Dr Rubicon JL Hardtop
The average dealer would blame everything on the hole blocker and try to void the warranty…..
Pig-Pen
Banned Camp
2018 JLU
jabroni
i use my key fob under my stock jack to help raise the jack since i did 2.5" lift.
i also use it when rocks arent available and im struggling to overcome an obstacle. careful not to driver over the button though as you may cause the key to knock down a tree or person.
Pig-Pen
Banned Camp
2018 JLU
jabroni
Wbino
NJ
that thing is great but $25?! must be made in the US for that price. that's a $7 chinese amazon product all day long.
lol. nothings made here. Thank Wall St. ?
And if you drop something in the middle of the night you don't feel like fishing for, $25 is pocket change. ?
