Water Pump Leak Joys
Mudduck
Jay
Michigan
2021 Willys 4door
Smelling coolant randomly and saw this. Coolant on top of the front diff. Can’t see where its coming from though.
Jeep Wrangler JL Water Pump Leak Joys IMG_0495
Mudduck
Mudduck
Jay
Michigan
2021 Willys 4door
I can’t tell…. There’s crusty coolant all over, from the top of the oil cooler down.
Jeep Wrangler JL Water Pump Leak Joys IMG_0499
Jeep Wrangler JL Water Pump Leak Joys IMG_0498
Jeep Wrangler JL Water Pump Leak Joys IMG_0496
jhackathorne
Denver
'21 JLUR
I have a 2.0L so not much help on location, but find out where your water pump is and check the bolts. I know on at least the 2.0L it is a known issue. We got back from a wheeling trip in South Dakota and inspecting my undercarriage for damage, I smelled coolant and found some on the top of the front diff as well. Luckily a buddy had the same issue and had told me about the bolts coming loose. I located mine and snugged them up and it stopped. Dealerships know it's an issue and typically remove them and use blue loc-tite from what I hear.
Mudduck
Mudduck
Jay
Michigan
2021 Willys 4door
Thank you for your response! I have an appointment to drop it off tomorrow.
Mudduck
Mudduck
Jay
Michigan
2021 Willys 4door
under warranty?
Yes. Still under the 3/36k thankfully. The tech working on my jeep is a jeep guy. Has a 23 JLUR that hes dumped about 25k into. I feel good about it… said they were a week behind but he’d get it on the rack for tomorrow morning anyway…. Nice
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Water pumps are no big deal on these, it will be quick.
Mudduck
Mudduck
Jay
Michigan
2021 Willys 4door
Water pump done and they also changed the timing chain cover. 5 days wasn't a bad turn around.
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
I went through 3 water pumps on my 3.6 in my WK2 within 48k miles. Water pumps are all too common on the pentastar.
Mudduck
Mudduck
Jay
Michigan
2021 Willys 4door
What the hell? That doesn't make any sense at all.
I'm not sure why the Timing chain cover was changed. I cant get a straight answer.
Mudduck
Mudduck
Jay
Michigan
2021 Willys 4door
Seems to be one of the weakest links. I've done a lot of reading on the water pump issues over the last few days.
mwilk012
Service
Are you sure it wasn’t the water crossover pipe on the timing cover? There’s no reason to R&R timing cover based on the symptoms unless they blew the threads out of the timing cover with an impact when installing the water pump.
