WARN ZEON winch notice
AZCrawl
AZ
2018 Granite Jeep JLUR
Geronimo
Boltz
2013 JKU , 2018 JLUR, 2023 JLR all DDs
https://factor55.com/product/flatlink/
This link is the regular flatlink in red.
They also have a multi link and a spliced in version. They enter shopping cart so I'm assuming they have them. All in red.
agordon117
Alex
Ohio
2021 JLUR HellaYella
Just installed my 90 degree lever. The biggest pain in the ass was trying to close it all back up. You basically have to shimmy the crap out of it in every possible direction until it finally closes flat, and then without letting go of it, start getting your screws in place to hold it. I had to shake it pretty violently while rotating and twisting to get whatever the hang up was to seat. Then I let go, and it backed out 1/16" and I had to do it all over again.
Wear disposable gloves, and change them frequently.
NYC_Bobby
Bobby
NYC
2018 JL Rubicon, 2018 JL MOAB, 2016 Renegade Trailhawk
I ended up finding it on amazon but it was sold out everywhere else. Amazon seems to be out now as well.
Factor55 has them in stock. I ordered one on Friday.
Tech Tim
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Krondor
Here, but soon there
2018 Punk'n Jeep Wrangler JLR
FulThrotl
Randy
Huntington Beach, CA
2018 JL Rubicon
In talking with Warn, this is not a problem when using the Warn mounting plate. It is a problem when using the Mopar mounting plate. Not sure about JCR’s or Rusty’s plates.
JCR's plate comes with a .030 shim plate to put between the winch plate and the winch.
that in theory will let the lever miss the edge of the bumper. dunno if it works, i didn't
need it, so i didn't use it.
understand, getting that winch in between the bumper horns requires trimming the edges of the horns,
and is like packing a marhmallow in a piggy bank. 1/16" on both sides, and you are touching the grill.
Tech Tim
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
No trimming needed with the Warn JL Rubicon mounting plate, ours went together perfectly.
agordon117
Alex
Ohio
The trimming is not a factor of which plate you choose, but where your jeep falls in the tolerance range. My frame forks, for instance, were so tight together that my bumper didn't even want to go back on. I had to trim about 3/16" from each side, then angle the forks. If I didn't, the zeon would not fit between the forks no matter what mount was used.
FulThrotl
Randy
2018 JL Rubicon
yup. what he said up there.... ^^^
as for the flawless frame welds.... my fab guy and i were under the back of the
jeep, looking at putting in a second gas tank, and took time to marvel at the
welds gracing all the frame attachments.
splatter-tastic.
Artec
North Salt Lake, Utah
www.Artecindustries.com
2014 JKU, 2020 JLUR 2019 JTR 2021 JTRD
We have just finished our Prototype winchplate for the Warn/superwinch winches for use with the Jeep steel bumpers
Tech Tim
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
Awesome! Looking forward to seeing them!
BostonBilly
Billy
Mass
2015 JKU
Look forward to seeing them and a spec sheet
Krondor
Got my kit and swapped my lever already. Aside from a moment of panic as the gears didn't line up even after being so careful, it went fairly well.
The moment I was able to get everything to click back in place, I had the biggest sigh of relief. lol
Thanks for the read Tim!
