Wall Mount Door Hangers
swflfireguy
naples,fl
2019 JLU Sahara
Retired Fireman
I use these: Ladder hangers , from ace Hardware. sturdy and I am able to anchor it into the block wall, I use them for all 4 doors.
Jeep Wrangler JL Wall Mount Door Hangers 1652280808904
Buster1
Ft Worth, TX
‘51 M38
Hey bud. I got lucky and had many choices since that is outside load barring wall and windows so many studs to work with. Between front and rear doors the hangers are 40” apart (center bolt to center bolt), the space between rear doors is 33” c-to-c. Here is quick sketch lol
Thank you!!
Chile1
Missouri
2018 JLUR & 2016 BMW X5M
Biotech Sales Management
how many feet off the ground are your doors hanging. I'm looking to doing the same but will use a 2x6 stud to keep things level.
hoag4147
Colleyville, TX
2022 JLUR XR
It is 6’ to the bottom of the ARC brackets. It is really preference on how high you want to mount along as they don’t touch floor. IMO, higher the better but they can be heavy.
Chile1
Missouri
installed the ARC brackets this morning using the DIY tips provided on this thread. Thanks to hoag4147 and the others for the inspiration/ideas...
Jeep Wrangler JL Wall Mount Door Hangers 1653245112253
Jeep Wrangler JL Wall Mount Door Hangers 1653245134426
hoag4147
Colleyville, TX
2022 JLUR XR
Look good ??. A tip on On using TLP. If it is an older version the bars on top are not open enough to miss the wider brace on JLs top (JKs were narrower). I cut mine because it didn’t set right in the rear. Also, if you can, leave back window open. It helps the top sit more level.
Buster1
Ft Worth, TX
‘51 M38
What are your guys thought on going higher up for the 2x6 for the ARCs?
Chile1
Missouri
You mean like higher than 6ft or something else?
hoag4147
Colleyville, TX
2022 JLUR XR
No issue doing that. I almost used my back wall and did over/under. Two doors top and two directly underneath. Front doors can be heavy but not an issue. It truly is a preference thing ??
Buster1
Ft Worth, TX
‘51 M38
No issue doing that. I almost used my back wall and did over/under. Two doors top and two directly underneath. Front doors can be heavy but not and issue. It truly is a preference thing ??
Thanks! Not too heavy to lift up it would seem.
Chile1
Missouri
Yeah. Like 7-8’ above the floor. Gets the doors a little higher and away from ‘the scratches zone.’
i'm 6.2ft and 6ft is the sweet spot for hanging imho.
macphisto13
macphisto13
H
Mustang GT but wanting to add a Jeep to my stable
Dude... you're missing a door. Did your Jeep only come with 3?
Zenmaster238
Jonathan
Louisiana
2022 Firecracker Red JLURXR
how much space did you need between the brackets? looks good!
also... Chi Chi Chi Le Le Le Viva Chile!
