Upper control arm skids? Alternative
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
You have to understand I’m not like gunning it or anything I’m just slowly driving over rocks rarely do I bump myself up stuff but my jeep is factory height so that’s the big problem, we working on that slowly but surely
Don't think I've Fubar'd the fronts, but I bent the passenger rear stock bracket before installing the Rusty's skids. It bent at the LCA mounting tabs, and I had to bend them back to remove the arms.
PropaneBender
PropaneBender
Benjamin
2020 JLUR 2.0
I have the borla and had to modify the skid for the double exhaust tail pipes
You’re a wild man going dual pipes like that on an off-roader id be scared af runnin that but it looks sexy 😂
Terrymo
Terry
2023 JLURXR 3.6 ET
i didnt know you could really even hit that part of the LCA lol. let alone that were skids for them. i have the rockhard lca skids and they are full bolt through and tough as nails. surprised to see them that weak for those. i guess RH figures no one would really be hitting there, except OP lol.
even if theyre bent, theyre still protecting. id say just leave them and take it a bit easier on the rocks.
I have skids on my skids because I pick shitty lines sometimes. But when I do drag across my skids, I try to go as slow as possible just to hear the skids screech in protest so I can justify the time I spent to install all of them.
PropaneBender
PropaneBender
Benjamin
2020 JLUR 2.0
Hey I purposely take harder lines now that I’m plated, because I feel safer doing so with all my plates
bd100
USA Midwest
JT
The Barnes plates look nice, but I'd be tempted to round that corner's leading edge a bit before paint and install.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
Got my Barnes front lower control arm frame mount skids
Fit perfectly.
Jeep Wrangler JL Upper control arm skids? Alternative IMG_2237
Jeep Wrangler JL Upper control arm skids? Alternative IMG_2238
Jeep Wrangler JL Upper control arm skids? Alternative IMG_2239
Jeep Wrangler JL Upper control arm skids? Alternative IMG_2236
