Uconnect CarPlay maps Bombing
Offworld_Colonies
Me
Los Angeles
2020 Wrangler Sport S Black 2.0 Turbo
Designer
My uconnect 7” about a week ago started to quit/ bomb out of the full size maps.
It will sound an audible blip… flash the CarPlay icon and then It will default to the small map Or quit CarPlay all together.
no issues playing my music.
I’ve tried the button sequence reset… that works until I turn off my jeep. I’ve attached a video of the issue… anyone experience this and or have a solution?
iOS is current. Tried both usb ports. Tried Apple and aftermarket cables. ??‍♂
jludave
The Isle of Long
IT Manager
Offworld_Colonies
Offworld_Colonies
Me
Los Angeles
Designer
Try rebooting the phone itself. That often fixes weird issues like this.
Thank you for the response…
Yes, rebooting my iPhone along with rebooting the actual uconnect we’re the first things that I tried.
Offworld_Colonies
Offworld_Colonies
Me
Los Angeles
Designer
What I had not tried was cleaning out the actual iphone
Connection port.
i removed some lint and debris that had accumulated there.
ive driven around for a few hours and this seems to have fixed my issue.
I’ll post here if this actually was the problem.
thanks
Offworld_Colonies
Offworld_Colonies
Me
Los Angeles
Designer
So the problem popped up again.
this time a bit more aggressively. The CarPlay logo flashed and blips a lot more often now. I still suspect it may be the iPhone port.
I have to collect another iPhone and see if it happens with said iPhone. Hmm…
Offworld_Colonies
Offworld_Colonies
Me
Los Angeles
Designer
Different iPhone and still getting the same issue :mad:
jludave
The Isle of Long
IT Manager
You can try pulling the fuses for the USB ports to see if that resets them. I forget which they are off the top of my head, but you can easily find them in the owner manual or online.
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
Not sure which ones they are for a 2020 but in my 2018 the USB fuses are F11 and F102 ( I have done this a few times on mine) and it was not because of issues like your having it was a power issue and I just pulled and checked the fuses, also you may want to pull the radio fuse F97 on mine.
The above fuses are for my 2018 so if nothing else look in the PDC cover to verify, I currently use a wireless CarPlay adapter and don’t have issues with Apple Maps but as we all know Uconnect is very buggy
Offworld_Colonies
Offworld_Colonies
Me
Los Angeles
Designer
Update:
Pulled the fuses.
still blips and defaults to the small map.
does it as well with Google maps but Waze is fine?
