Turn signal lights
Jeep2018jl
Samsung
Los Angeles
Jeep jl
Hi I just replaced my fenders for aftermarket fenders. And I try to install the turn signal lights. When I take off the bulb and I installed the new lights for the fenders. Show on display turn signals off. It’s any adapter to install to prevent this situation
omnitonic
Michael
Southwest Virginia
2021 JLU Willys in Sarge Green
truck driver
Perhaps stop drinking alcohol and sober up. Try again tomorrow.
If alcohol explained his nonsensical message, it would probably make sense to me, because I am drinking alcohol. It does not. Maybe if I do another shot, it will finally make sense? ?
slowpoke387
'23 JLURXR Firecracker red
At least he posted it more than once ?
Gregj
Greg
West Texas
Ok I’m not going to bash the op, since he just joined I’ll welcome him and try to answer the questions.
From reading your post I assume you bought a jeep and wanted to change the fender flares and the lights are giving you problems. I believe the Jeep had halogen lights and you are trying to hook up LED’s, yes the Jeep will have the “turn signal out” display in the dash.
You will need to change the settings for the lights to LED to clear that error. There are several programmers that can accomplish these changes, do a search for Tazer, JScan or Flashcal as they all can make these changes, I personally use the JScan app as it is reasonably priced.
The Programmer forum is located Here and the lighting section is Here
Gregj
Edit to add: some people use resistors to fix this, I personally don’t like that solution.
aldo98229
Aldo
Bellingham, WA
Market Research
Welcome to the forum!
I’m sure someone on here will come up with the answer to your question once they are done drinking.
Edit: looks like the poster above just did!
