Turn signal error message on dash
Geauxjoe
Joseph Restivo
Lexington,NC
2000 Sahara 22 Grand Cherokee 21 Freedom Sport
Hello I have a 2021 Jeep wrangler sport with factory halogen lights. I just replaced the halogen’s with led switch backs. I used my J-Scan and reset all the setting to led active. Since then the error message will not go away even when I put the factory bulbs back in. The j-scan message keeps saying control short circuit to battery or open. That message stays even if I use my j-scan to delete the message. Confused as to why the error message want be removed even when i reinstalled the factory bulbs. Please help
Geauxjoe
Geauxjoe
Joseph Restivo
Lexington,NC
I’ve tried everything to erase the error message and everything I’ve tried the message after 20 seconds of the turn signal being on comes back. Don’t understand. I followed a YouTube video on home to cut the light monitor off so it want trip error codes and still it trips the error code. I’ve even installed led load resistors and still have the error code. The lights I used are Alla Lighting 7443 switchbacks for my 2021 Jeep wrangler sport. I went with all of Alla lights the headlights turn and fog lights. And they weren’t cheap. Thanks
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Do the lights work at all?
It's possible, if you powered them up before adding load resistors, you blew a fuse or the module.
The code description you're getting is saying that once commanded, the module is not seeing any current draw. So, the circuit is either open to the battery (blown fuse) or shorted (Also, blown fuse). If the fuse did its job, you should just be able to replace it. If it didn't, then the module likely took the hit.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
How did you wire in the resistors? Do the lights work? The code set for both sides?
Geauxjoe
Geauxjoe
Joseph Restivo
Lexington,NC
Yes the lights work. And I wired them according to the instructions. I tested the wires and found the positive for the turn signal and connected one end to it and one to the ground wire for the light connector.
Geauxjoe
Geauxjoe
Joseph Restivo
Lexington,NC
And yes my dash error states both turn light are out. And when I log into my j-scan it says there is a control short to battery or open
Geauxjoe
Geauxjoe
Joseph Restivo
Lexington,NC
Yea the lights work just after 15 seconds or so the error message pops up in the dash
Geauxjoe
Geauxjoe
Joseph Restivo
Lexington,NC
Geauxjoe
Geauxjoe
Joseph Restivo
Lexington,NC
mwilk012
Service
Can you test actual resistance across the circuit ?
Geauxjoe
Geauxjoe
Joseph Restivo
Lexington,NC
Update:
Thanks for anyone who read and replied.
I finally got them to work with no error message in the dash. Not sure why but I went back into the j-scan led light settings menu. Went down to the front turn light diagnostic present setting. Never did anything to this setting before but for kicks went in to check it. It had deactivated listed so I just hit deactivated again and hit ok and rebooted the system. Turned the key off got out closed the door waited for two minutes to make sure the system went to sleep. Then got back in turned it on waited for the system to start tried the turn signals and they worked without an error code being tripped!!!!!!
I’m going to give this week using them and if anything changes will update.
Thanks again for all that read and responded. Love this forum
Geauxjoe
Geauxjoe
Joseph Restivo
Lexington,NC
Update: neither the error code or hyperflash lights come back on all week. So I’m assuming I was able to trick the computer and fixed the issue.
Thanks again
dgulia
Raj
Toledo, OH
2020 Jeep Wrangler Sport JLU; 2019 Ram 2500 Laramie; 2019 Jeep Cherokee
Glad it worked out
